Dunerat
Dec 10 2002, 06:48 PM
DO THEY MAKE A SET THAT WILL USE THE STOCK LIGHTS AND KEY? WHAT IS THE BEST SET UP TO GET WITH A STOCK STATOR?
THANKS
JAYSON
5150HARVEE
Dec 10 2002, 08:38 PM
I have the handle bar set-up and am still running the stockers. As for the stater, the stocker will work fine. I'd go with two floods instead of 1 spot and 1 flood. (as ALBA advised)
MWBbanshee
Dec 11 2002, 04:20 PM
thoose lights work great both friends i know love them . the brackets that hold the light to the mounting plate seem to break for no reason though,it's happened to both bikes
5150HARVEE
Dec 12 2002, 08:30 PM
I sure hope so. My boyz broke a total of 5 brackets with the side mounts.
ChoppedLiver
Dec 19 2002, 11:48 PM
Stonehedge,
You are 100% right. We had a rather large batch of compromised material that when stressed got brittle. We have not had a single failure on the new/redesigned ring. Remember that all metal components of our lights have a lifetime warranty. If you have a broken ring, call us and we'll get it replaced for you at no charge.
A little secret. We've totally redesigned the mounts on the lights. The middle "mounting ring" is now gone. We've also eliminated the side to side pivot on the side mount brackets. Way clean and way stronger. This is for new lights only and won't be upgrading on existing lights. They'll start shipping in January.
Dunerat, If your running the stockers our kit comes with 2 35watt lights 1sp/1fl. You can get a 50/50 kit and loose the stockers or switch between the stockers and LS. If you run the stockers and the 50/50 kit you are over pulling the stator and are running a risk of battery drain, which means no starting if allowed to drain too far. It won't affect the motor as the ignition has its own output on the stator. The Electrix stators for the Raptors are 300 watts. Put a couple 100w and really see!
Thanks for the continued support! If you need anything or have any questions, give me a ring.
[ 12-19-2002, 11:53 PM: Message edited by: Ron @ Lazer Star ]
