Fireballsocal
- 681
Damn. I saw 4" flange and thought it was correct. It's 4" O.D. but 3" I.D. K&N should have something that should work. I agree that I would prefer an air box but as a street rod, the filter might work. Will heat be an issue? It's not the hot side but still gonna be hot. As an aside, a 4" tube with pie cut bends would make a nice attention getter to draw the eye and get you the space you need for a standard clamp on filter. An air box might detract from what you want to do and would need to be close to ideal in size for the motor to pull from without giving unwanted characteristics like surging off idle.I like the rough size of that filter. That is a 3" and my turbo is a 4". So similar size just a little bigger. Think I will call K and N tech department and talk about airflow. Lot of CFM at 600hp.
