My understanding is the overheating issue is really an issue with the windshield. When I was driving mine you can feel the radiator heat getting swirled back into the cab and essentially back over the radiator. I believe they are releasing the rear windshield today to block the fan heat from being circulated back into the cab. Is anyone experiencing overheating if they don’t have a windshield?Overheating: has anyone tried removing this shroud:
The offset is a little worrying since a lot of a fans airflow doesn't go straight back, but a lot gets flung out to the sides. Not sure what ducting is used to seal the fans to the radiator as well, but depending on how this shroud is built, could be recycling air or stalling some of it.
