J Alper
2'' Hollow Upgrades
This is a couple of Kits we converted, as the tires get larger the Combo spindles just can not keep up, so some board members asked me to put up some pictures
Matt's upgrade
another set Anton Spindles
Edited by J Alper
Desert Dynamics
ultra light sand car, had light weight spindle was a converted beam car,
ken car,
bfd upgrade
DD car with inlay support on steering
DD Pre-Runner
Rick Tate BFD
Edited by J Alper
Jason Weeks Desert Dynamics Prerunner
Edited by J Alper
Desert Dynamics Sand Car
TIG weld option
NICE work Jason - new screen name "Spindle King"
it started with me and sandrash when we bought the stu 10.75 and broke a bunch of snouts the rest is history,
thanks Alex!!
Edited by J Alper
Great thread.
I have an 07 SU Sand Pro 2 mid-engine at about 2200 lbs. running STU 10.50 x 17 Razor Backs on King Kong snouts. Do you think I need 2" hollows?
Great thread.
King kong, snout's should be good on the shaft with that size tire, I would just have them magged ever other year, the snouts are strong but the mounting
surface is still the same size as a combo, so the shaft to not break in half like a combo but some times they break out of the plate
Great thread.
Just a question, what prevents the same thing ^^ from happening when putting a strong 2.0 snout on the same spindle that either combo or KK spindles were on? Not bagging, just asking.. and I thought you used to slip the 2.0 over the spuds instead of cutting the whole plate off. did you change the procedure?
I am doing this over the summer and getting the jalper hubs too
GREAT UPGRADE in my humble opinion! spoke with Mr Alper the other day and what a great guy!
:poule:
Great thread.
if you take do the calcs on the diameter, you almost have 3 times the mounting surface, or 3 times the welding surface, with us you also get a large .500 mounting plate
that it welds to,
Great thread.
Thanks for the advice. However, the pics of the 2" hollows do look very beefy and inviting.
this should help
with Kartek bolt on plates
new spindles for jtc1369
tab zone econo spindle then cut down 3''
this should help
for us knew-bee's.......... which are these, left to right?
What kind of bearings go on those 2" hollows? are they standard roller bearing like these?
Edited by Bobalos
correct they use the standard tapered roller bearings
Time for me to upgrade. What would you recommend, will King kongs cut it or should I just do it right the first time and go with 2" hollows? I have a dejong monster Manx. Care weighs in at 1640 lbs and front is on 33" Baja pros with aluminum Douglas wheels. Reason for upgrade is I snapped off a combo last year and just the other day pulled the spindle out plate and all.
Edited by thecertified
