John@Outfront Mtrsprts
Outfront's Gen 5 Funco Ready For Summer Rebuild
Just brought my car into the shop for a 4/5 month redo of my Funco Gen 5. As you know this car is a work in progress, It started life as a
typical Gen 6 four seater. Mendeola Sequential 5 speed. Two years ago I cut the back upper part off to make it a two seater and to move
tons of weight forward. I added a hollow sway bar. Turbo moved to on top of the tranny, there is zero intercooling piping with the turbo
mounting directly to the intercooler and the intercooler directly to the intake. Subaru EZ30 3 liter at 750HP on high boost.
Here is a list of the current upgrades as the car sits now:
sway bar
25Gallon fuel tank on E85
radiator is 19x36 twin 16 paddle blade fans, radiator mounted on the floor rails for lowest CG
turbo and intercooler moved over the tranny for more weight forward
fuel tank mounted behind seats, more weight forward
3.0 quad bypass in the rear, 3.0 dual bypass in the front, King race
7/8 upper heim at hub assemblies
12x24 intercooler with twin HD 12" fans, air temp controlled
reinforced rear arms, 935 cvs
Douglas bead locks, billet center 15", fronts with reinforcing ring
frame has been reinforced in critical areas when built as I have cracked my previous one in 7 places
front rack mounting tube had to go .188 wall as .125 even cracked before
wheel base stayed the same at 122" but car looks short because the rear cage was shortened by 8"
custom light bar mount
functional side air scoops
rear hubs have four lower bolts upsized to 3/8 bolts (for big jumps)
small 6 piston calipers in rear
chromoly beard seat frames with rear upper tabs
race tech seat belts
hargett two handle shifter (forward for upshift)
twin new Outfront fold down whip mounts
7 X 18 R2C oiless air filter
lower radiator line goes through the frame
lots of rear cage bracing, semi X
upgrade list:
new super bright fluro green like always
auto air ride suspension with 4 gallon tank
possible Grey area rear hubs and brakes
1" lower front heims
reinforcement rings on rear rims
new rear tires to start off the season right
rebuild tranny (2seasons old, the longest I have had a tranny last)
couple more bars in the front end, have two new cracks on an already reinforced area
1 or 2 custom made camera mounts (active)
radio (finally)
intercooler scoop and valance
motor to be freshened up, maybe an experimental 3.5 liter if time permits
This list will be added upon im sure
This tube attaches right above the front strut tower. it normally is a 1" bar this is 1.25 and is developing a crack, it will get two bars there now
This is two of my Larger trapezoid intercoolers welded together. note zero intercooler piping on either side
EZ30 flat six 600hp at 11psi, 750 @18 psi, e85, super short, motor is only 17" long and the CG is more "below" the crank than above
Can't wait to see it in new clothing. Been way too long
a couple shots of the large radiator on the floor of the car and the large inside mounted air filter, helps with the sand exposure
custom Rear sway bar, because I run no rear seat my sway bar links can be more upright than what Funco does on their cars
custom stainless headers
reinforced rear arms (extra plate added near the sway bar)
note the new frame bar just behind the CV joints, this really stiffens my rear end, goes up and intersects with 5 bars
Can't wait to see the finished product
lower water line runs through the frame, just cleans up the piping
I have a long bolt and spacer now, but will weld the spacer direct so there is no threads at the shear point. planning on doing a beefier 1"
lower heim as I have sheared off both heims at the same time on something I still could have driven out of. No I don't think this is now going to
break something else.
dual masters on the brake system is a must, note the extra gas pedal sensor for future DBWire (cableless) throttle
Did you abandon the GTR engine?
You mean this one? no its for my 2005 SU car, I know others have asked but to be honest I am too busy with the shop and work has not
slowed down, its a great problem to have but it has caused me to not progress on my own cars. that's why im getting a head start on my own
car this year.
I think about it and walk by it daily :nag: Funco First, then I will have time :sraptor:
This would be a HP wars contender, but just too many irons in the fire. Its mated to a S4D
car this year.
Good to hear you haven't abandoned this project. I also have an SU Sand Pro 2 mid and have been looking forward to seeing this car completed.
I love these threads!! Cant wait to see it all done!! I really like the Idea of the Upper seat mount!
DAM, Great Job on the Funco.
I noticed the air pumpers for your helmets how do you like them, and which ones are you using
It's got nothing to do with the way you drive it, does it?
Whoever did it...that is a bad weld. DON'T NEED TO GET INTO THEORY...they wondered with the stinger.
They just didn't get base material on both parts. It's not cracked on the other edge of the weld that is deeper.
I love the attention to detail in your cars and going against the norm or standard that is seen on the other relatively cookie cutter cars out there. I'm still building my car, but I use your ideas and theory as inspiration for my build. Keep up the innovation and good work. And photos of course also!
With heavy g loads i have destroyed the frames of two seats before beyond any repair. you can get this done even on a mild steel frame, it was a while ago but i popped for chromoly and the tabs
I dont remember, i bought it from Mckenzies, i Have not used it yet as i dont have a helmet for it. i usually lead but thought that if i dont, i want to still be right on the next guys tail
Hmmmm?
This tube area has cracked on three funcos i have had, the first only had a 1" bar, after that cracked, they removed it and put two bars like a peace sign. we called it the out back bars. they never cracked
them on the gen six this would have been a 1" bar, but we upped the size. It could be a little underbraced, that was a Funco weld. it will be getting two bars there regardless. note that my shock tabs were increased to 1/4 plate
by request because i tore the 3/16 tab off. in a previous gen 4
real world testing, i break it then make it better, tons more photos coming
It may be an area that needs attention, but THAT particular weld missed the mark..
Shit, you can almost see the lip from the left overs from it being coped...
Edited by Kraut_n_Rice
Going to be a good thread to watch, cant wait to see the Funco all fancied up. Keep the pictures coming.
2059 lbs with 10 gallons of left over fuel, with a S5, 934, sway bars and an itsy bitsy Subaru motor :sraptor:
the weight right to left is incredible even. front to rear looks like a mid engine but Im a rear engine. This weight distribution is "only"
possible with a Subaru motor. Jumps like a dream
power to weight=.364
Righteous
Kraut n Rice, what is your opinion on the other side of the car? it also cracked in the same place, contrary to your last post, this crack is on the deeper
side of the weld & no wondering stinger.........?
any time the radiator is not the highest water in the cooling system and if the upper neck is not at the top of the tank it could trap air, thus
the need for the bleed tube. this hose goes up to an expansion tank above both the engine, radiator and upper water line
this radiator sits on the floor of my car, with water this is 50 more pounds lowered to as low as it can go---say limbo :sandtrap:
Brandon, one more close up
this is the lower water line through the frame. the 90deg was both made from .120 wall 4340, then I spliced a short piece of thinner material
(chromed) with a nice bead. Why? just too busy down there with the sequential and a water line that comes from the already low Subaru motor
This is the 3 lb, 4 gallon tank for the auto air ride suspension, running out of room and because its so light I might weld a few tabs on the fuel tank
I agree, it will get an additional 4" bar in the area
