32hotrod
Tom pro type 1 turbo
Tom pro sand rail with car to car led light bar.   Has heated seats for you comfort.   Has chrome front and rear suspension with chrome bypass shocks all the way around.    Has dual chain drive and secondary 120 amp alternator.   New radiator.   Motor specs 10-1 je turbo pistons, Carrillo rods, high volume oil pump, arp bolts through out, race cut trans tool steel shift shafts billet 30mm output shaft, windage tray, lockup clutch,.  Turbo is a water cooled Garret 2871 has intercooler with scoop.   Has a Tom pro reverse box that had new bearings and chain last year.   Car makes  296 hp to the ground at 14# boost and 374 at 22# boost.   Has a two stage boost controller that is adjustable and selected with a switch.   Car is very reliable and crazy fast.   Asking 25,000.  0626111605.thumb.jpg.5c000d18a420d23d83335d56da09312a.jpg
Sweet car glwts!
