John@Outfront Mtrsprts
So it begins, My Gen 5 summer 2018 conversion, Outfront Style
15 hours ago, John@Outfront Mtrsprts said:
what you don't like the Corvette look?  here is with one per side and a wing mocked up.  I know this stuff looks crude with duct tape but I love doing it that way, I set it up and look at it for a few days then change it up, settling on my favorite. The two horizontal cage bars will be permanently welded in the car, from there down will be removable, the motor will still come out the bottom with no intake on which is how I always pull this engine.  Lights are 3" in diameter
What's up with the wing?  I never pictured you as a "looks" man.  I prefer function over form(other than color ;))
I like the double light but I agree it would need to be frenched/semi-recessed in to a panel to look right
Why not fit some Subi lights in there?
turn them the other way..........
so you're talking like aluminum panel the whole back area (it would be at an angle) then recess the bottom of the light into it?
Calling Grease monkey, pic of the rear of your car?
hmmmm...., not sure if they would mount easily.   I did think of the Polaris 1000 rear lights but cant get over the stigma of having a grown up razor
I like the looks of the double lights.
well I am not a looks guy, everyone knows that but maybe its time to step it up, I am going to have a new painted car and don't want to miss out on looking a little bit like the new Funcos:sraptor:  do you like it?
I like it with the duel lights and the wing if done tastefully. Nothing wrong with adding some cool factor to your build.
Do I like it?  Meh, my opinion doesn't really matter. ;)
so just to instruct and show some terminology in valve train. here is a cut away of a 6 cylinder head, and cam bucket. Im having some custom never made before cams for a motor im working on, here are some typical issues. note in the first pic the cam lobe is almost touching the bucket, but the bucket base has touched the head. This dimension should be in the .020" range min and mine is less than that, but its hitting a casted area of the head (not machined) so this could be worse with other valves, when its this close this has to be checked on all holes "before" the valve job is performed. the next picture shows a bucket, titainium retainer and a test spring at full lift, note again how close the bottom of the cam bucket is to the head, in this pic its .010"  the third pic shows the valve completely closed, in this scenario you could measure your installed height like pic 4.  The areas of concern are maximum bucket travel, installed height, compressed height (installed minus lift of cam) wire specs like coil bind and spring pressure at both closed and open positions. It is possible that there is not enough real-estate to get the job done. but you can make compromises. Lets say you need a spring that has 70lbs on the seat (valve closed) and to get that the spring needs to be installed at 34mm of installed height. once that is obtained by retainers and spring seats the game starts. if you had 11mm of cam lift then when it is fully open the height of the spring is 23mm high. you want to be at least 1 mm away from coil bind. lets say coil bind for this spring is 22mm, then in this scenario you are good to go.  if the spring you used needed to be at 32mm installed height to get you proper seat pressure of 70 lbs, then at full lift the spring is now 21mm high--it is coil binding and this is catastrophic--she's going to blow  In my case I have another issue that the bucket has no more travel at this lift the options are to go with less lift, have shorter custom buckets made (not a good idea for bucket stability) or we could cut the cam lift profile on a smaller base circle. This is what im going to do. by cutting the base circle down .020" will give the bucket to head clearance about .030 clearance and allow for a taller installed spring height which may open me up to a different spring to get the job done.  Cheers
You lost me at "So..."
It's kinda like belt tension on the drive on one of your mowers. Too tight, no stop.  Too loose, no go.  If shit ain't right, it don't work..  LOL
Here you go. Slow mo at 8500 rpm.
Another cool vid. Valve seat view at the end.
Edited by onanysunday
On ‎4‎/‎16‎/‎2018 at 6:00 PM, I'm Sorry said:
If lights are in a full inclosed one peace i would say two per side, if not then one per side
my favorite so far, Corvette, Ferrari, Outfront.............  LOL
this panel will go all the way across and have a small panel on the back side so you don't see wiring
18 minutes ago, John@Outfront Mtrsprts said:
That is the best look right there. Simple and clean lines never go out of style.
In 10 years many of the "Popular" looks (Over done, curved Alum Fab) right now will look as silly as some of the crazy 90's paint schemes do now.
That will look great.
are those the actual springs they use........? They look awfully wimpy.
here is my actual high end spring, almost double seat pressure than stock, once I get my custom made guides I will do another mock up with the cut away to see the actual setup
Looks like what we used to call a bee hive spring. Or is that just the photo.
Some more pics of the amber and low red lights, its a keeper, two more lights on the way! and some florescent green paint to get a better view
when the brake lights are on its like stupid bright.  the low beam red is awesome (not as good in the pics) but you see every LED not just a glow, really cool lights
Reminds me of a Nissan GTR tail light setup. It's a Subi-san.
Love it!
Does look like it's got some taper to it.  Natural frequency tuning tricks?
