John@Outfront Mtrsprts
So it begins, My Gen 5 summer 2018 conversion, Outfront Style
Years of minor changes, additions, subtractions and relocations all coming together in this thread. John, super cool of you to share all of this. Cant wait to see it without bare metal and glowing in the dark.
Plexiglass cam/ timing cover with a billet standoff? Possibly backlit by green LEDs?
Seriously nice work and great info in this thread, carry on...
Thank you all for your suggestions, this is my final design.  Am I a Fun-Craft or an Alumi-Co?  not sure but I like it.  the light scheme will be low red outer lights and inner amber lights for day time and night, then when brakes applied all outer go full power. They are so bright that the picture came out dark trying to compensate. The lights are in a temporary steel 3.5" tube.
I also have something that has come up so I wont be posting for 2 weeks, then back at it full steam ahead. Tell me what you think, I'm always taking suggestions
That looks great!
that looks great John,  very interesting about the skid plate makes total sense.  parts can be replaced back not so much.
Good show John.  It all came together real nice.  Like the way it all flows in the same direction.
I like it. It's going to look great all finished up!
yep, you will always hear stories, especially for back seat passengers getting a spinal compression due to an instant stop.  If your car is used in sand only, there is real no reason to have a skid plate. there is nothing to "poke" a hole in anything. having a skid plate under the tranny is the same thing. suppose you take a jump and land high centering a little sand bump..... i would  like the sand to hit and pass through my two bars and tranny case rather than hitting, and coming to a dead stop on my skid plate.  Have you ever heard of someone breaking a tranny in half with out a skid plate--no.  I have seen some compressed Subaru oil pans, even though we reinforce the bottom with steel plate, the sides are not strong.  On that note all of our oil pans have a small 3/16" rod welded across the face of the pickup so that if it is "cased" badly. the pick-up would bend up with it and not starve the engine.  A pan is only $270. pick your poison
Im just getting started, if you notice in some pics i had run the lower water line through the frame. this was a cool idea but would have been even better if the car was first made that way. I did it after the car was done and there are too many pipes and welds that the water had to pass through and not leak. I dont want to take a chance that after my car is painted that a leak spring up (its not as if i haven't had cracks in my frame right?) so i will be cutting this whole right frame tube out of the car and installing new tranny and engine mounts too.  My motor mounts have cracked in multiple cars i have owned so they will be made out of 3/16 Chrome Moly plate, then gusseted and bolt bosses welded on too. I will admit that when i did this upgrade 4 years ago i welded the right frame rail in a little crooked in one plane. it was .25" lower by the time it reached my cage and it drove me crazy so this will be corrected on this redo.
list of next things to do:
right rear frame rail, replace/delete water through frame
final rear cage
upgrading to a 1" lower front heim on both sides
new turbo/intercooler location and aluminum work
extra upper tranny support
new header
That looks really great!
On ‎4‎/‎24‎/‎2018 at 9:32 AM, John@Outfront Mtrsprts said:
the battery switch at the back of the car or a hard to reach area like inside a door etc is not helpful if you had an emergency. I once had a loose metal object rolling arounfd the floor of my car. it happened to lodge between my battery disconnect and the SS clutch line. it killed my car, hmmm I get out and the next thing I see is smoke coming from my car, the clutch line is now orange for about 6" I kill the battery switch, throwing sand, freeking out. I pause for a moment and then its getting oranger!. now im really freeking out. I try yanking the battery cables off my car (all the while thinking what the crap is going on) I couldn't pull them off. I had to get tools out and quickly disconnect. after relaxing for a moment I realized the metal object was on the battery side of the switch so it didn't help to turn it off.
Well anyways my battery switch is within arms length when im seat belted in, its also 4" off the ground for future rolling objects.
the damage was my clutch line needed to be replaced as it sprung a leak
I always use the Battery Disconnect to disconnect the Negative cable. That way you never have this problem and you still can immobilize the car with it.
I welded plate steel on the bottom of my pan and also along the side for extra strength. No skid plate.  John, I really like reading your posts. Never would have known about the gusset kit. Got mine all welded in today. That is a lot of welding! Should be super strong now. Thank you for the nice kit.  I added one more little piece on the top where both of mine were cracked. You mentioned the steering rack mount and now I am afraid to look at it. :blink::sha:
sweeeeet
On 4/23/2018 at 10:50 PM, John@Outfront Mtrsprts said:
ok or is it this way?  This probably looks the best but does leave my motor most exposed, looks?
that's the one
i like that as well tooooo many options, I'd dub that one (Johnny 5 is a bad a$$)
Edited by jugernaut
found better image
I like the final design.
Call this what it is John - FunOutfront
What about funoutback? Oh that's right dam car cumpany...
John your car is coming out nice.  Also can you post a link to your new lights..
Thanks
Outfrontco
Thanks
This is what he posted in a separate thread
https://www.ebay.com/itm/3-motorcycle-LED-taillight-brake-light-turn-signal-round-universal-fit-1PCE/401382469648?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2648
Did the same to my motor.  Paint didn't last long, but no issues with the motor.
In our group, we call them "skid pans".
That's funny, we call them a glide plate, helps u not lose momentum when you scrape belly on the ridge when transitioning sideways from bowl to bowl...
