Sign in to follow this
Reece
35x10x17 cst tires in the sand
Want to get some opinions... I run 10.5 x 17 sand tires unlimited razors, but think the tires look small on my car. I don't want to run 15" wheels and go to a  10.75 x15 because I like the look of the 17" wheels. Going to a 12.5 is not an option (look funky with a 33" rear). I ran across these 35x10x17 cst tires and was wondering how they would work and look if i shaved down everything on the tire except the singular tread in the middle. Do you think it will have enough bite compared to the razors? I know people like the Mickey Tompson tires in the sand, and I think this might be a similar setup, but a 17" wheel option.
CST CH68 Tires
-Reece
I think that if you had them shaved down, all except the center tread they would look good, I don't think they would have as much grab as the razor tires, but they guys I have talked to that have them seem to be happy. I would run em...
How about the extreme 10.80-17 Apex tire?
Why not try some shaved 35" Baja Pro's?
great tire and they look much better than the stu
needs a 17" wheel they are only 15" tires
I would try them and get them buffed down.  I have the baja pro shaved and they work real good.
I figured that's why they were out of the picture.
Reece, the only thing i'd be worried about with those cst tires is there's a lot of tread on the side wall, so doing a full shave to the sidewalls might get a bit close. They'd probably work well though
Quit beating around the bush and just put the big  tires on that rig. It will look way better.
I think you will like the look of these and a great option
New S5 wont hold anything larger than a 33" with how hard I drive, and 33" rear tire will look awkward with a 12.5 front.
What do the current tires measure height wise?  I run the 35" MT Baja Pros totally shaved down, no rib, and I have no complaints.  Can't justify replacing them for the $100 I'm into the for.
Create an account
Register a new account
Sign in
Sign In Now
Important Information
