Sign in to follow this
Bob & Walker
2017 Kawasaki KX 500 AF $10,000 (909) 478 4791
 Kawasaki KX 500 AF Green sticker Calif for sale $10,000.
- Build cost 2017 $14,149.41 ( We have all records/receipts -goes with custody of the bike
-Build Sheet: June 2017 ( all receipts / invoices and spare take off parts included(see long list) incl ---
-tires/wheels/paddles/3 tanks/pipe/ engine cases & bearings
-Green Sticker - Calif
-Frame & Chassis ( take off was from 2006
- We started by taking it down to the frame and removing all the bearing Guides
- All new Hardware/ bolts / nuts ( mostly Hardened Steel Allen’s, some Titanium) most nuts are “Locking” and all -have been lock tight thread
-Boxed Service Kawasaki Bulkhead
-Hammer Coated Frame
-Hi Cap roller bearings / race/ steering Stem / Stem hardware
- Re designed Air box / K&N Hi Flo Air Filter/ modified Intake Manifold( new Hamper, Holder Element &
Damper
- All Frame Bearings , Pivot/Sub Frame/ Swing Arm/ Suspension Lower & Upper/ front & rear wheel bearings /
front and rear brakes ( piston / Clutch, Front & Rear Brake Cables– ALL NEW
- Aluminum Radiator Guards – Hard and foot (Brake/ Clutch) levers ALL NEW
- Plastics / Seat/ Go Pro Mounts/ Voyager Computer & GPS/ Shrouds/ Aluminum Skid Plate/ step plates/Roller Chain Bearings/ Chain/ Frame Collars – ALL NEW
- Baja Design Front & rear LED Light Kit with HO Stater
- Suspension is “Factory Connection” (Rear) & Pro Circuit Front
- Pro Circuit Triple Clamps
- New Impact Race Wheels
- New MOTO Z Tires ( Moose Liners – no tubes)
- Acerbis 3.5 gal Fuel Tank
- New FMF Knarly pipe ( modified) new springs / O rings
- Aluminum disc covers front & rear
- Pro Taper Bars w/ Alum Throttle body
- Hammer Head Axle Blocks
- Front & Rear Hydraulic Brake lines-NEW
- Whip Flag
- Aluminum Caliper Guard
- New Aluminum Wheel Spacers
- Front Tree / Handle Bar Bushings – NEW
- Billet Gas Cap
- New Kill switch
- Primary Drive rear chain guide/block – NEW
- Warp 9 Titanium Bolt set rear Sprocket
- Many bolts anodized or powder coated
Motor – ( take off was 1989 kx 500) new rebuilt / LA Sleeve … stock cc / Lightly ported & polished
- Balanced Crank
- Completely New Motor(top & Bottom end) OEM , Wiesco Piston / Ring and Pin Bearing
- Carburetor – fresh rebuilt / polished bore/ gaskets/seals
- Water Pump impeller
- All Seals / gaskets/ hardware/ Bearings- NEW 100%
- Renthal Sprockets
- Factory Racing Cover / Guards
- Compression release Valve ( easy start)
- New Hoses with heavy duty stainless steel Barrel Clamps
- Hi Pressure Radiator Cap with Gauge
- Co Medic Basket Cover
Bob DeLozier 909 478 4791
Create an account
Register a new account
Sign in
Sign In Now
Important Information
