Sign in to follow this
Bob & Walker
2017 Honda CR 500 AF $7500. (909) 478 4791
2- Honda CR 500 AF
This build cost was $11,917.30 ( We have every receipt
Im selling it for $7,500.
Motor – ( 1994 take off) Complete motor rebuild top & bottom all bearings seals, gaskets and assembly by “ Eric Gore 2 Strokes 630 825 5645 ( all OEM stock)head and cylinder studs are new-
Frame – (2010 Crf 450) Built by “M Works” chassis , box’d bulkhead
• ALL ITEMS BELOW ARE BRAND NEW
Wheels -tires –spokes – rear sprocket – cables – ASV Levers – Hoses – all pivot Joints Pivot Works – Devol Radiator Guards & Braces – rear disc guard – Master Cylinder kits /OEM rebuild- Radiator Temp cap – N Style Seat – Grips – Renthal Chain – plastics – Go Pro Mount case – GPS mount- Tubes- whip- skid plate – Water Pump impeller – 100% of all Gaskets – All Hose clamps new- K&N Air Filter – Hammer Head Axle Blocks – adjuster bolts – Axle Nuts – Carburetor completely rebuilt with oem kit – BRP Chain Guide – Brake Pads – Coolant – Oil/AMS oil 10/40 Brake Fluid 100% new – air box gaskets – exhaust gasket – Reed gaskets
Exhaust – Pro Circuit pipe with FMF Muffler
Risers – Pro Taper
Bars – Renthal
Suspension – New Factory Connection
Foot Pegs- “Flow Motorsports”
Shift & Brake Foot controls- Hammer Head
Acerbis – 2.5 gallon Fuel Tank
Front Light – Baja Designs / Custom Stater by Rick Stater (Installed by Chris Reddin at R3 Fab
Hardware – Oem – Tifco Industries Hardened Steel …as much as possible ( case included…lots of left overs
The bike was taken down to the frame and all frame Bearings – Bearing Guides / swing arm and steering neck bearings are new and rebuilt from bare aluminum frame.
Everything was installed with red “Lock Tite” and all bearings and joints with good grease.
Bob Delozier
909 478 4791
909 809 7241
They are both bad ass. I love these bikes and this one is super nice. That crawler is pretty damn sweet also.
Create an account
Register a new account
Sign in
Sign In Now
Important Information
