just2dune
4 seat x3 scat track tire pressures?
I just finished up adjusting on my suspension for the maiden trip to the dunes over Thanksgiving. I was just wanting some advice from people that already have a four seater set up what are they running as far as tire pressure for the Scout tracks front and rear. Wednesday can’t get here soon enough. Thanks
What pressure did you have your tires when you adjusted your suspension?  I would think you should be around 10psi would be fine.
I still had the Maxxis on there when I did it but I had them all at 20 psi
The tire pressure for the Skats (I assume those are 32" set up) should be around 12psi in the rear and 10-11 psi in the front.  My friend runs that with his set up on his 4 seat X3.   I run 12 psi in the rear and 10psi in the front with my 32" set up on my 2 seat X3.   This is the tire pressure we ran over Vets weekend and it worked great.
If you go lower the car will feel spongy as the tires will flex.
I have the two seat xrs and run 13 in the rear and 10 in the front.
Ok thanks everyone 10 and 12 is where I will start. Thanks
