Jonesin'
Switch Pro
On ‎12‎/‎12‎/‎2018 at 2:37 PM, J Alper said:
I sent it back to you check your PM, has not even been a full day
Payment sent Jason.
On ‎12‎/‎9‎/‎2018 at 8:31 AM, punkur67 said:
I have one and it works great. You can control anything you want. Just use the switchpro to trigger an external relay for any large or inductive loads. I put relays in for my fans and fuel pump and everything else is direct.
Can you PM me on where you got the wire tags? I like those
I used a label maker with clear shrink tube over the labels. Makes it very nice to identify wiring
Bro, High five on the flawless wiring job.
Edited by Dirtywhiteboy
Thank you
3 hours ago, punkur67 said:
Thank you
Are you in Cali, and for profit would you wire a future stacker for me with switch pro to control everything from winch to hydraulic door?
I have a label maker but, don't think the letters get that small...
The label maker I have allows you to put two lines in the same label. I printed on both lines and cut them in half.
Dang, I'll need to find one of those label makers...
Where are you located I have one you could use.
I'm in a land far, far away called Illinois...
Yes yes you are sorry
Picked one up from Alper. Can't wait to get it hooked up
Getting ready to hook one up on a new build, bought it at SSSS (sorry Alper I’ll get the next one for my truck from you). Any tips on making it function for the ignition switch? I have an idea on wiring it up but not 100% sure it’s correct.
pm sent
Here is my setup that my friend wired up when I redid my car this off season. It is under the panel so cant see the actual unit. All the white wires coming up to the bus are switch pro.
Can you message me? I'd like to pick your brain. That's a helluva set up!
