Sign in to follow this
sausage450r
Fix for leaky suzuki/kawi petcocks
I just acquired another lt50 and from past experiences with lt80’s and my other lt50. The stock fuel petcock.   Sucks! Suzuki uses a vacuum operated petcock (poppet valve) rather than a traditional on/off. The way the system works is; a line runs to the carb and another runs to the intake elbow, vacuum from the motor  pulls the poppet valve open allowing gas to flow. Well as everyone in cali knows are fuel destroys these systems within a month of being idle. Smelling up your garage and toyhauler with fuel. the design is a solution in search of a problem. Im sure some suzuki engineer claims this as his pride and glory.  Effing get rid of it!
the stock vacuum petcock runs 110$ from suzuki and is always a back order item. A factory carbureted yamaha raptor(quality) petcock is 32$ at your local dealer and is an exact bolt in match for both the lt50/80 and now you have an on/off. Cut a section of fuel line and plug (i used stainless steel round head rivet) the intake inlet. Now route your fuel line to carb the same as before. No more smell or stains in your toyhauler/garage.
Edited by sausage450r
GREAT Post / We did it on the LT80 too...…..the stock factory set up is a nightmare!!!!
:poule:
Also works on first gen z400/kfx400’s.
I just picked up a z400 not long ago and was trippin on the no "off" wtf?! This makes sense. Good stuff mang!
Do you know if I can use the same Raptor petcock for an LTZ250?
Had that probelm on my lt50 and LTZ250. Replaced both. I used an aftermarket one for the lt50 but an OEM one for the LTZ250.
Just in case it effs up, I could hopefully use the Raptor petcock.
I do believe they are all basically the same flange/bolt pattern
Great! Thanks!
I just replaced the one on my kids 80 with one from an LT160 the hose barb was the same as the 80. I have the stock vacuum one if anyone needs it. I just replaced it before the inevitable.
Just to verify. The vacuum port that activated the petcock should be plugged or can it be left open?
Anything that sucks should be plugged.
:cool:
Yes plug it. It pulls vacuum directly from intake elbow between carb and head
yup plug the port at the carb with a vac cap.
