FFaaron
2016 BFD Revo turbo Hayabusa sand car
BFD Revo. Purchased as rolling chassis from BFD then power train added.
Exterior:
Full tig welded 4130 chromoly chassis
Full aluminum body with wing trunk
Custom valved walker Evans shocks
30" single row LED lightbar
2 led pods
930 CV's
4 wheel disc brakes
Gray area hubs
Method bead locks with STU tires
Jeffco reverse box with cutting brakes
Full aluminum skid plate
12 gallon fuel cell
Dual fiber optic lighted whips
Interior:
Custom jet trim seats
Carbon fiber vinyl wrapped interior with custom stitching
AEM digital programmable dash
Rugged radio car to car and intercom with Bluetooth
Quick release steering wheel with tilt wheel
PRP 5 point harnesses.
Motor specs:
Motor is fresh with Dyno tuning and one trip on it. Car 2 tunes, one for pump gas which makes 280 hp to the wheels or a race gas tune that makes 305hp to the wheels.
Hayabusa motor
Wossner turbo pistons
Carrillo rods
Back cut 6 speed sequential trans
Aluminum intercooler
Lock up clutch
Larger injectors
Cosworth ECU 4 position tune capability
Hi flow oil drive gear
Tom pro alternator kit
Dailey engineering 1.5g 3 stage dry sump oil system
Nitrate coated crank
Brand new optima battery
$30,000
located in Escondido, ca
760-717-7287
Edited by FFaaron
Wow, what a cool car. The design and attention to detail is incredible.
 Is that a cutting brake on it?
GLWTS
How exactly does the cutting brake work for a car like this, if you don’t mind me asking? I was always under the impression that cutting brakes would not work on direct drive cars, as the brake would just cut power to the whole drive train instead of just the one tire? Or do you just essentially use it as an ebrake?
That would be true on a direct drive one. But with the reverse box it acts as a differential.
Interesting, I was told the reverse box just switches the drive direction through internal gearing. I didn’t realize it actually acted like a differential. If that’s the case that’s pretty cool! Whatever the case, that’s a really sweet car!
Some might, but the jeffco acts as a differential. Thanks! It is a very well built car, it is actually designed as a dual sport if you throw some dirt tires on it.
Very cool car!. Buddy of mine here in Michigan is interested in it! Why the single chain setup vs the dual setup? Also, what are the perks of the tom pro alternator kit? I have a 4 seater with a hayabusa power plant and tom pro gear box.
Private message sent! Trying to keep the add from becoming a 6 pager 👍
Create an account
Register a new account
Sign in
Sign In Now
Important Information
