sinverguenza
Combo spindle to 5 lug
X2 on this. About to buy the Wilwood wide 5 hubs for my front end, but if someone has something for sale PM me.
For starters Safety really should be in the front end,  starting this thread really sound like a beam car,  just my opinion but If a rhino or a rzr800 has front brakes so should a long travel sand car, so I would run a brake made for a sand car,
second, I would add a second shear point on the steering, we should all remember the lighting mqueen car
VW wide 5 is 5 on 205MM
Willwood 5 on 10.25'' bolt pattern
205mm + 8.070''
the snouts are a 2'' hollow,
So you will need front rims for this spindle,
if you did this it would not be a bad way just non conventional, but so buckshot does there own thing
Now looking online most wide 5 are the rear hub made for full floater axle this is not with a drive flange,
the drive flange is extra
Warning,
if you go to the true front wide 5 snout it is smaller than the Combo snout
if you go to the rear hub on the front the drive flange is almost the cost of the hub
you still need nuts and bearings, on the wide 5 its, a la carte
then last are the rims the steel rims are the same price as the race trim aluminums
then if you want matching rears you would need the wide 5 wheel adapters for the chevy bolt pattern micro stub $75 each
you can get aluminum wide 5 beadlocks from weld $315 each
but I have seen combo VW style brake kits for $300-500 complete with calipers used on the board, put out a WTB
205mm + 8.070''
Warning,
Thanks Alper. I really appreciate your time and the info.
I have a set of the Jamar Pro X 5 lung spindle mounts that ill make you a killer deal on comes with disc brakes and everything will need.. They have never been used
Can you PM me a price and location?
On ‎3‎/‎15‎/‎2019 at 6:24 PM, sinverguenza said:
Can you PM me a price and location? PM sent
Create an account
Register a new account
Sign in
Sign In Now
Important Information
