Jonesin'
LS variation help
I’m looking to go with an LS in the next couple years.  Actually LS engines that come out of different vehicles that are completely different from one another but, are still stamped  5.3 and 5.7. I’m looking at using an LS4 out of the FWD V-8 cars (Impala and Monte Carlo SS).  They are so plentiful  and can be found for dirt cheap. Has anyone used one of these?
Posted (edited)
The crank is different, but biggest problem is the different belhousing bolt pattern on ls4.  LS1 and 5.3's are pretty cheap or you can to lq4/lq9 block.
Edited by 1newbie
update
Definitely! LS 5.3L is your entry level to low end power on demand. I did an Ebay LS1 at 2k delivered years ago.
I had an L33 but regret selling it now
Is there an adapter available for the LS4?
Just checked Kennedy’s website, there is an adapter for the ls4 and front wheel drive 5.3’s
Also checked car-part dot com and they are available under 1000 bucks. I don’t think it would be an issue but there are some differences in the accessories on these vs a rwd engine, mainly the water pump.
Not all ls series are aluminum block though. For a buggy I'd prefer an aluminum block for the weight savings.
I’d like to have aluminum also. I’d much rather use an RWD aluminum as my first choice
This is an interesting topic.  I might be upgrading soon.
Posted (edited)
Just use any salvage yard 5.3 (not an LS4) you wont notice the weight difference when you are using the car, your wallet will think you for it. The aluminum LSs are getting spendy and harder to find. They are out there you just have to pay more for them.
Edited by fortyfour
If I can find an aluminum I’ll get it. If not, I’ll get an iron block
the blazer had the aluminum 5.3 they run about $1000
typically we pick these motors up, new pump new timing chain, change the oil pan to a car style,  change the intake to a car style, change balancer water pump, and add a factory harness, we always use the 24, for drive by wire,
typically motor with harness adapter clutch and headers looking like a car motor is about $3600,
these blocks can be bored to a 5.7 and then a 383,
this is also what we use for our 454 Darton sleeve builds
What are the good heads to use?
Largely depends what you are building? If it's staying a 5.3 I wouldn't waste money on heads, if it's a 5.7  ported 243's will be the best. If your a 6.0 a 4 inch bore can fit ls3 heads and if the bore pops up around 4.125 you can start looking at ls7 heads.
the motor size make a difference, if you stick with the 5.3 the 243 is a good head but it needs to be the NON ls2 head needs to be the 243 made for the truck,
this is due to the combustion chamber size,
if you are changing the pistons it does not matter,
but if you change the pistons, then the 5.3 block we bore to a 5.7 then add the 4.00 crank
the 5.3 block we talked about on the phone makes good power, if you want some more then a mild camshaft under .600 lift with the 5.3 pistons will help out allot, try to stick to .583 or less with the flat top pistons, you can do a .600 but the pushrod length should be no more than .035 plung
$3600 gets you a 5.3, ready to drop in a buggy?
Power steering?
Thanks
Power steering?
Thanks
$3600 correct with power steering all billet pulleys and factory ecm unlocked ready to start,
New - oil pan fbody, new alternator - new balancer f body - new water pump F body - new power steering pump, new adapter plate - new timing chain
Used flywheel and adapter plates while they last,
Used Ls1 intakes
for $3900 it would come with new bearings and rings and new lifter trays, with head studs and new head gaskets
 Thanks for the info guys! Most likely I’ll just stick with a stock 5.3 for a season after I change the transmission and then have it gone through in the off-season.
Create an account
Register a new account
Sign in
Sign In Now
Important Information
