Ms. Havasu
2005 SANDCO LT5 STROKED LS-2
2005 SANDCO LT5 STROKED LS-2 402cu (6587 Cu CC) in 620+ hp PUMP GAS
5 Seat Long Travel Full Body Sand or Desert Car with Wing Trunk, Overall length 16'4"  Removeable Roof Rack and a Removable Spare Tire Rack,
Chassis was built to SCORE Race Standards car currently qualifies for SCORE SPORTSMEN CLASS.
This has been a Play car not a Racecar!  Car has only been used a few times at Ocotillo Wells and mostly in Glamis Sand Dunes.
 The CHASSIS is 1.5” .095 wall Chromalloy with a 1.75” .120 wall Chromalloy Torsion.
All Suspension, Shock mounts and Main Frame is .120 wall Chromalloy.
Has Boxed Rear 934 Mid Board Trailing Arms with 6 Piston GearOne Caliper/Disc Brakes and Sand Style Tubular Front A-Arms with GearOne 2” Hollow Spindles with 4Piston GearOne Caliper/Disc Brakes.
Vehicle has 24” useable Travel with a 5” clearance at full compression measured in Dirt Trim, Body Panels, Ceiling and Interior of Wing Trunk are Lined with CARBON Fiber Vinyl, Floor is Rhino Lined.
 FULL Length 3/8" Aluminum SKID Plate. King Shocks with Triple Bypass with Double Limit Straps on ALL 4 Corners.
- Engine Redline Tuned - STROKED LS2 402 Blueprinted and Balanced Engine 620+@ Crank,  Chassis Dyno 480 RWHP with 450 RWT onPUMP GAS 91 octane. All Forged Internals complete with CNC Ported GM #243 PATRIOT PERFORMANCE HEADS Stage 2.5 Big Valve Ported and Polished Heads. No expense spared on parts and machine work, complete list of engine components available. Engine has 3 two day trips on it since completely redone.
- Mefi 4b Computer. Entire Car is Professionally Wired using Weather Pack Connectors along with Relays and Fuse Blocks.   Remote Battery Disconnect. Battery is ODYSSEY PC-925
- Custom Headers Copy of the GM C5R Factory Race Header  Tri-Y Stepped and Merged Headers complete with X-Pipe.     Ceramic Coated Outside and Thermal Barrier Coating inside.
Interior has nice Size Latching GLOVE Box, Beard 2” wider 2” Taller Suspension Bucket Seats and a Beard Suspension Bench Seat in the Rear ALL with Adjustable Head Rests that raise and rotate forward. CROW 5 Point Padded Harnesses, Grab Handles and Wrist Restraints. Center Console from Front seats to Rear with Drink Cup Holders. Color Lowrance 480 Baja GPS, Full Assortment of Dash Gauges, 5” Monster TACH with Large Remote Shift Light, LED Gear Indicator, Race Radio with CAR to CAR, 4-Link Pro PCI Intercom w/ 4 Carbon Fiber Stereo Head Sets,  Headset Hangers, Alternate Power Port in Glove Box, Interior Cock Pit Dome Lights, Sweet Detachable MOMO Steering Wheel wired for PTT and 120db Hella HORN
- Menedola S4 Sequential Transmission with single Handle Haggert Shifter. Transmission was Completely Rebuilt by Dave @ McDowell Performance with ALL Newest Updates and New R&P all Gears, Bearings, Shift Forks and Seals
-ALL NEW GERMAN 934 CV’s with Kartek Chromalloy Polished Cages  Race Prepped and Polished Center Stars
- 934 GearOne Centerboard Hubs with New Custom 300m Axels manufactured with NHRA Certified 300m by Ryan @ PPM in Ontario, CA Made in USA -Trailing Arms Rebuilt Center Board Bearings and Seals and NEW FK Heims - 6 piston GearOne Rear Brake Calipers
- 9” Forged KEP Twin Disc Clutch Stage III rated for up to 700 foot lbs torque
* All these items in this section completed at the same time and has 2 short Two Day trips since completed.
- Aeromotive A1000 fuel pump
- Aeromotive 100 micron Pre Fuel Filter and 10 micron Post Fuel Filter with shutoff
- 2.5” King Shocks Front and 2.5” Rear 3 tube Bypass rear
- 2.5” Coil Carrier with Valving and Remote Reservoir Front and Rear
- 33" STU SandBlaster Pro #3 Paddle Paddle Tires on Douglas Beadlocks Wheels Rear - Sand Tires
-10.75 STU Front Steering Tires - Sand Tires on Douglas Beadlock Wheels
- 6 BFG Baja T/A 35x 12.50x15” Aggressive Dirt Tires on BTR Beadlocks Wheels
- 35x12.50.15 Shaved BFG Baja T/A Mohawk Steering Tires -Sand Option
- Custom Rear Wing Trunk Lined with Carbon Fiber Vinyl
- Custom Center Console with Drink Cup Holders Front and Rear
- MOMO Detachable Steering wheel w/ Sweet Mount hasHORN and PTT wired into Steering Wheel
- Beard Suspension Seats with Drivers Seat Adjustable forward and back
- Full Mechanical Gauge Instrumentation along with 5” Monster Tach and LED Gear Indicator
- Race Radio with 4-Link PCI Intercom, Carbon Fiber Stereo Headsets, driver and passenger PTT
- Baja Designs 9” Halogen Lights at A Pillar along with 5-ea 9” in Light Bar on Removable Roof Rack
 Amazing well maintained Buggy $45000 obo
Call John (928) 208-9017
image.thumb.png.906b0ffa8043e0db4cfb7885efcfc119.pngimage.png.c4805033668578c22bc6b9ed3029fe43.pngimage.png.58ce67dd1b33be8a8472a279a79d0ab7.pngimage.png.c2d31856c17e5ed8c4817e4a3ca25353.pngimage.png.ba897ec4c995326064297c2a8bc70138.pngimage.png.d916056815653e13cf717b1c9fa290f0.pngimage.thumb.png.b2243adfb88a7fbb3406114e6189bf0c.png
Great add and very nice car
Create an account
Register a new account
Sign in
Sign In Now
Important Information
