Sign in to follow this
ACME
1991 Bronco Prerun/Play/Overland Solo Motorsports Built
Baja Proven 4x4, adult owned & maintained, not mobbed or abused. We built it as a course cruiser/play/chase/Baja explorer rig with a "sleeper" mindset so it blends in and is low key But works awesome! Set up to chase/prerun/overland vehicle but has a ton of potential as a great Baja prerunner! It's been pro built and maintained with approx 5K miles since the finished build. Went through initial build, then decided to do the '19 Baja XL/4000 Nav Rallye and upgraded and prepped it all last fall, to be bullet proof in Baja (almost all of the work done at Solo including prep). It finished the Baja 4K with no issue in Feb, and it's only been out a few times since to chase for friends. Other commitments will make Baja & desert trips limited over the next few years and we hate to see it sit... Plus we have a ton of other toys we don't use enough so we've got to thin the herd.
Strong 5.8L, AT/AC/PS/PDB/PW/PDL/CC, Manual T Case 4x4, 140K OG miles, SOLO Stage 4 suspension. Front is Fox 2.5" Coilover and bypass w/2" Bumps, Rear is Deaver w/ FOX 3" internal bypass (DC Shock Svc), FT/RR Lockers w/4:56 gears, rear is a trussed 9" with 35 spline Currie axles/disc brakes w/hyd pkg brake. New PS system with high pressure Pump & Box and 1 ton steering with a w/cooler & new spare pump, Trans has been gone through, Warn Hubs, Solo motor mts, fuel system gone through tank to injectors. Complete stock interior with reclining PRP's on Solo sliders in front, 5 point harness w/removable cross bar for easy back seat access, stock rear seat and huge locking "Truck Vault" parts/chase box (w/spare everything inside; ready for Baja) or rear seat can be removed and swapped to a folding storage rack-overland fold out bed configuration w/air mattress so you can sleep inside. Back 1/2 family cage/sliders/Solid Body Mts, Solo roll cage pontoons to frame installed for sliders so a full blown Solo prerunner cage can be installed and 1/2 the work is already done. Custom front skid plate w/Superwinch tucked behind stock bumper, 2-10" Baja Designs LED bars in grill, 6-35" BFG KO2's on PPT Alcoas (2 spares: 1 on custom rear carrier bumper and other goes inside on storage box next to jack and is brand new), Custom rear tire carrier w/hitch and removable gas can racks, new race jack w/mount inside, new spare driveline mounted on cage and tons of spare new parts: Alternator/Starter/Electronics/Fuel-PS Pumps, PCM etc + much more. Everything works as it should, just serviced and ready to go with a ton of stuff not listed. $24K with 2 Icom radios/PCI Intercom and Lowrance 7TI GPS $22K w/o electronics. Price is firm, pink in hand with a clear title so it is Baja insurable for stated value coverage meaning you can insure it for what it's worth in Mexico.
Now imagine how happy the wife and kids will be with AC/Heat and out of the rain, plus they'll be able to cruise to the store, town, Pismo, the mall or go anywhere they want in street legal, locked, 4x4 comfort!
I don't get on here much so please call or text 6two6 5one3-6455
Not looking for a trade but may consider a Playcraft Tritoon deal: No bikes, off road toys, RV's, Jeeps, crawlers, or other boats; we're really not interested and don't want to waste your time...
