Dave In Florida
Best Battery For A Buggy
Red top Optima. Just replaced one last year that had 13 years on it. Good info on the different Optima batteries. https://www.optimabatteries.com/en-us/support/battery-basics/redtop-vs-yellowtop-vs-bluetop-battery
On 9/11/2019 at 11:08 AM, 2turbofords said:
My Odyssey pc 925, pair are dated 2013 and still going strong believe it or not! I was thinking of pulling them out for this season and putting them on the enclosed trailer and putting a new pair in the buggy just for Peace of mind.
do you think 2 batteries would handle a stereo system ? been thinking about adding another one.
Yes, put in a selector switch. you can run battery a and b all the way to the hill switch it to battery b, run on your stereo for hours until it dies...switch it back to battery a start the engine and drive away.
Noted good to know thanks man
If you use a battery selector and it's not on "both" whipe running then only 1 battery will charge.
I use an Odyssey 925 for the start battery on a high compression LS3 and a small interstate deep cycle for the B battery which runs everything else.  I also use a Blue Sea ACR also for the stereo and lights.  I just replaced my Odyssey after 9 years and it worked perfect when I replaced it.  I just thought it was time.  They are always on a battery minder with a desulfater.  Can't go wrong with an Odyssey or a blue top.
~jw
On 9/11/2019 at 10:01 AM, Grease Monkey said:
I dont use a battery tender. Just turn off the battery switch and let it sit for months at a time. My Oddesey has been great,
This is the most important item when it comes to batteries!
Get a good battery switch that turns everything off. EVERYTHING.
And my vote is for Oddyssey too. Sandcars, RzR, etc.
Edited by matt86m
Battery relay like this guy fixes it:
https://www.partsgeek.com/gbproducts/DC/5294-07165829.html?utm_source=google&utm_medium=ff&utm_content=DN&utm_campaign=PartsGeek+Google+Base&utm_term=1975-1990+Ford+F150+Dual+Battery+Solenoid+Relay+Standard+Motor+Products+75-90+Ford+Dual+Battery+Solenoid+Relay+1989+1980&gclid=Cj0KCQjwn_LrBRD4ARIsAFEQFKuj18y-5Lk8QIAgEJQjsWIEBiB1e22x61n0XYRceQa20DFPxmmQ7_gaAlI8EALw_wcB
Run ignition switch to the signal, audio/whip light on one side, engine/starter on the other.
Since 2005 when I built my car all electrical is run off of this bad boy 250 amp.  Was working fine but I replaced it once just because I wanted to be proactive.
Certainly safer than running heavy cables to driver-reachable space.
My wiring from day one was full overkill. Not one blown fuse or issue in 13 years. Big giant grounds as well.
Nice!
Was talking about big battery cables accidentally grounding out from a wreck or misplaced screwdriver or whatever. :bigrin
I had an Optima Red top in my Tatum for 11 years, started 1st crank, every time! Ran car around the neighborhood once a month to maintain a good battery level, and keep the fluids flowing throughout.
