indianjoe 43 Posted October 14 Ok stupid question I have Fox by passers and coil overs I put a new wheel bearing in and I am getting ready to charge the shocks with nitrogen do I charge them both at 150 psi or just the bypass? I have had internal by pass before so I never had to think about it Quote Go to top Share this post Link to post Share on other sites
socaldmax 1,066 Posted October 14 (edited) It should be 200 psi in both. Edited October 14 by socaldmax Quote Go to top Share this post Link to post Share on other sites
indianjoe 43 Posted October 14 Awesome thx Quote Go to top Share this post Link to post Share on other sites
justdirt 2 Posted October 14 I would think it depends on if there coil carriers or shocks might need more information Quote Go to top Share this post Link to post Share on other sites
chopshop 26 Posted October 14 I thought King recommends 150 PSI and Fox is 200 PSI if possible charge them at full droop Quote Go to top Share this post Link to post Share on other sites
socaldmax 1,066 Posted October 14 15 minutes ago, chopshop said: I thought King recommends 150 PSI and Fox is 200 PSI if possible charge them at full droop You're right, I just assumed he was correct when he posted 150. Quote Go to top Share this post Link to post Share on other sites
SCHMIDTY 169 Posted October 14 You can put 200 in Kings as well without issue. Quote Go to top Share this post Link to post Share on other sites
jwest2sh 252 Posted October 14 Depends on your setup...I run all of my foxes at 250psi. I know some guys who run them up over 300. Quote Go to top Share this post Link to post Share on other sites
J Alper 455 Posted October 14 1 hour ago, jwest2sh said: Depends on your setup...I run all of my foxes at 250psi. I know some guys who run them up over 300. I do the same I keep a bottle in the trailer and adjust them depending on the weekend Quote Go to top Share this post Link to post Share on other sites
jjoseph99 118 Posted October 17 On 10/13/2019 at 9:41 PM, jwest2sh said: Depends on your setup...I run all of my foxes at 250psi. I know some guys who run them up over 300. On 10/13/2019 at 11:34 PM, J Alper said: I do the same I keep a bottle in the trailer and adjust them depending on the weekend So what does upping the pressure help with? Bottoming? Chop? something else? Thanks Quote Go to top Share this post Link to post Share on other sites
socaldmax 1,066 Posted October 17 1 hour ago, jjoseph99 said: So what does upping the pressure help with? Bottoming? Chop? something else? Thanks As you increase the pressure in the shock, it pushes against the shaft intruding into the body of the shock. It doesn't affect valving, but it does add a kind of a spring effect pushing the shaft to full extension faster. 1 Quote Go to top Share this post Link to post Share on other sites
indianjoe 43 Posted October 17 I went from 150 to 220 psi the front end came up a bit for sure Quote Go to top Share this post Link to post Share on other sites
jwest2sh 252 Posted October 17 (edited) 14 hours ago, jjoseph99 said: So what does upping the pressure help with? Bottoming? Chop? something else? Thanks I usually run Higher pressures in the dunes for the sharp transitions and G outs. It ramps up pressure when you get closer to bump and lessens the hard bottom out hits. I run lower pressure when I run hard pack because there are less G outs and jumps but more whoops, rocks and hard edges. It takes some of the harshness out of the suspension. Edited October 17 by jwest2sh 1 Quote Go to top Share this post Link to post Share on other sites
