Sign in to follow this
sandroosten
LS1 MEFI 4B need help
last time i had a problem you guys answered the question and helped me so much.
now my friend is having a problem.
he can start the car and run it hard with no issues, then if he putts around for a second or lets it idle and then trys to get back after hit he acts like it is in limp mode and wont reve above 4k RPM. i can shut the car off then turn it back on and start the process over again.
ideas?
How long does the car have to idle, or put around for before it does that?
a minute or two.
Does the car have an scanner port? See if it kicks any codes
Are you sure its a time related thing or is it Engine Temp related??  (a scanner port would be REALLY helpful).
the stupid thing does not have a scan port, but i did look at which wires it takes to check codes and I am going to jump them and do a ghetto one just to see if it is throwing a code.
It should be against the law to make an EFI system w/o a way to hook something to it, to see what is going on with it.  LOL.
i could not agree more!
As Bobalos said, make sure it's not temp related. The MEFI should have a temp shutdown on it so if the motor sees to high of temperatures it'll go into limp mode.
unless my temp gauge is messed up its not a temp problem.
it cruises around at 180-190 and maxes out around 210. If im not mistaken the mefi goes into limp mode around 235 degrees
I would guess the temp gauge is a different sending unit from the temp sensor that goes to the ECM.  but........... if you cant see inside the ECM, then how would you know????   I guess just swap out the sensor & see if that fixes it, but thats shotgunning @ its finest............
Your temp sender for the PCM could be faulty, and showing the PCM that the temp is high, even though it is not.
This.  Your gauge uses a different sender then the PCM.  Should be a standard chevy sensor.  Ohm it out and check the chart to see if its reading correctly.
Mine was doing this too. It was the intake temp sensor. It was thinking the intake air temp was too high and sending it into limp. Turns out the p.o. put the sensor in the wrong place and it would get heat soaked. Moved it, and problem solved.
awesome we will give this a shot, thank you for the input.
this actually makes a lot of sense, we just put a different intake on it before the problem started.
was talking to lance Dunehoon and he was also saying that they like to see the airintake sensor in the manifold for turbos but for natural they want to see it in the Airfilter intake tube before the throttle body,
My intake sensor is actually connected to a little mount next to the air filter outside of the intake. I double checked with CBM to make sure it was satisfactory and they said yes no problem because in theory it'll be the same air temperature as it would be just past the filter into the throttle body. So if you want to do a cheap and easy test, take the intake temp sensor and zip tie it somewhere in the area of the filter and go run it. If that solves the problem you can work on a mounting system or figure out where to move it on the intake
Kinda similar to how mine was, it was zip tied to the fuel rail, then it ended up between the fuel rail and intake, obviously it gets too hot there. I machined the sensor base, turned the threaded section down, turned it into a barb, and put in the intake boot just before the throttle body.
Yep exactly. Except my filter mounts straight to the throttle body so I didn't have the room to do this so I machined a mount that bolts to the side of the throttle body and the sensor goes on that. Hope this helps the OP solve his issue
thanks for all the help.
hoping to get this thing out before the weekend to test, Ill keep y'all updated.
kind of makes sense, it has a ProComp Aluminum Intake and the old intake was the plastic one
Hope it helps you get it figured out. It does make sense, having the air blow over the top of the intake helps keep it a bit cooler, but sitting and idling could cause the iat to see more heatsoak and put it into limp. If you're out in the dunes this weekend my car will be at the ceremony and you can see how I mounted mine. A cheap and easy fix
I just got done babbling this same exact issue..... Took me two trips.
Call me if you want 714 321 0748
