mxbullet
Update 11-28-19 mid engine v8 mendeola
Just bought this car and pulled the transmission to have inspected was popping out of 2nd gear , took the trans to JG transwerks in Anaheim and the issue was a loose main shaft nut . Completely took the transmission apart and crack checked everything and replaced 1st and reverse and put in new bearings and seals and oil have a receipt from him
The car is a 2010 mid engine v8 . Main tubing is 1³/⁴ and front arms are 1¹/² nice rear trailing arms with jamar micro stub. Has a freshly rebuilt mendeola 2d(have receipts) with PBS cable shifter . The engine is a 383 small block , 4 bolt main block, edelbrock heads , edelbrock airgap intake , nice roller rockers and electric water pump and a off road edelbrock carb. 15gallon fuel tank
King shocks all the way around
Disk brakes jamar front and rear
Rugged radio with new headsets
Cbr radiator with fans
Complete set of beadlock paddles and btr beadlock desert tires
Asking $14,500 obo that's one of  the cheapest buggy with a v8 and a mendeola car
In the process of moving the wing further back on the car to help with the appearance20191125_144155.thumb.jpg.1e556d7bc3cf5a071ef0d039b1c172ba.jpg20191125_141022.thumb.jpg.e718df5def3a63af65a168d669707c31.jpg20191115_161331.thumb.jpg.22e98d11db39ad5c32be867ca75a399e.jpg20191111_092839.thumb.jpg.b6c58b5e4b0ea27affcec29c5892a114.jpg
Edited by mxbullet
Hit me with a offer .
Update got to drive it .only pops out if 2nd , 2nd does not grind and sounds fine
syncro ?
1 hour ago, MGM/FRP said:
syncro ?
I'm thinking so
Update . Only pops out of gear in 2nd and when you let off . The gas
Looks like a good time.....how long and how heavy?
I'm not sure . It's not very long .
Will you sell just your paddles?
Yes for 7900 and I'll throw in the car
No tape measure?
That's what she said.
2 hours ago, spize909 said:
No tape measure?
13ft
Give me a call or text 562 631 4402
Removed transmission and sent it to JG transwerks to get fixed
Just heard back from JG transwerks. And the main shaft nut backed off
Trans is getting new bearings and put back together,  everything mag checked good
Bump updated first post
