Rockwood
Rockwood's Jeep XJ Build
Did you use anything special to get the undercoating off prior to welding in the frame stiffeners?  Seams some really struggle with it.
Wanting to tighten up the steering with the x-over/1 ton kit, figured the frame kit would be a decent buy too..
My old boss has this XJ:
I was just talking to him... and he mentioned he was trying to chase down some slop in the steering.  He found some worn out joints and stuff... so he replaced 'em and went to give it a feel.  He had somebody wiggle the wheel and could see the slop was gone in the steering gear.  He got in the Heep and wiggled the wheel and was still getting lots of steering wheel movement before he saw the tires move...
...then he noticed as he moved the steering wheel his bumper was moving back 'n forth.  Ruh roh.  He's looking at: http://www.boostwerksengineering.com/BWE-Comp-Mount_p_14.html to fix it.  Maybe something to think about before the steering box and your whole front end try to rip out of the Jeep.
-TJ
Edited by tjZ06
I'm not seeing how that is better than a steering box plate, and beefy bumper...minus the lower support.
Both of which I have.  My whip is kinda second hand chit built.  When I turn it squeaks, creeks, and pops.  Shits worn.  While driving it I look like I'm mixing phat beets....:dunerdude:
My whole steering column moves like 2” pretty ghetto. I know it’s gonn fall in my lap one day
These misalignment spacers are excessive.  Could be less than half as tall...WAY less leverage on the bolt.  Did this come with the kit?
Could also help limit the tube "swing" and ultimate clanging (you added rubber) if the rod end rested on the pitman arm.
That might not even be the right kit, or the complete fix for him.  That was just what I thought he said it was... he hasn't ordered yet AFAIK, so not sure if what he's getting sets the steering up exactly like that pic.  FWIW he already has a pretty beefy bumper, but obv it wasn't enough.  I think a lot of his problems started when he tried to winch a big Winnebago onto a trailer and things got bound up...
-TJ
I usually use the harbor freight poly discs:
Work great.
The creams and pops are usually the frame telling you to eff* off. Lol. Beef the rails before it ends up like mine.
Never thought of that. Might try it, though it does articulate quite a bit fully flexed and turned.
And....
Whoops.
Sheared the locating pin on the driver’s side leaf spring. Kept looking at the front steering/track bar because it wouldn’t track. Noticed the rear when I got home (towed, luckily). Cheap/easy fix at least.
While cutting of the short arm brackets Saturday..I think I found the cause of the loose steering and noises.  The track bar drop mount hardware was very loose, and the bolt that mounts it to the axle was also loose.  Didn't really get a chance to drive it when I was done.  It was late, and I was beat.
Nice find. My steering box and track bar kept doing the same, think the frame was flexing enough to let them get loose.
On 3/2/2020 at 6:44 PM, Rockwood said:
And....
Whoops.
Just a Jeep doing Jeep things!  But seriously, glad it didn't get ugly on the freeway or something...
-TJ
Posted (edited)
-TJ
Yeah, we were doing over 60 down Pole Line Rd.  Could've been bad...
That being said, the U-bolts were completely fine, so would've just gotten bad enough to pretzel the driveshaft and take out the transfer case.  Probably wouldn't have fallen off unless it got REALLY bad.
Edited by Rockwood
Sounds like a party...
-TJ
Took her apart.  100% my fault on this one: never re-torqued the U-bolts after replacing.  They worked themselves loose and that pin was subject to shear loads it should never have seen.  Should be re-assembling tonight if I can find a local source for grade 8 U-bolts (auto parts places only have grade 5).
All fixed up and re-torqued after 100 miles. Local axle shop bent me some new bolts. Got about a turn or so out of the inside u-bolts on each side when re-torquing.
Nice, glad it's fixed up.  We all goof up sometimes... me more so than regular people.  ;)
-TJ
-TJ
Yep. Odd part is the U-bolts I got from the parts store stripped when I went to re-torque the passenger side that was still intact, only 50 ft-lbs, so who knows how long that would’ve lasted.
-TJ
Just noticed this wasn't my Jeep, LOL.  Good taste, your old boss. :bigrin
And the rear shock install has begun (Fox 12" 2.0 Emulsions).  The leaves will only use about 10" of the shock, but it'll give me room to grow in the future, especially if I get jiggy with it and 4-link the rear.
Measure 4x...
Initial chalk lines were about where the shock needed to land.  Then I flexed her out:
Flex.thumb.jpg.1f9013a3d7e8edf768f77180f0ce59bf.jpgFlex2.thumb.jpg.4e4d556835a798bff5bfe0e854deafd9.jpg
And realized there's quite a bit of wheelbase change as the leaf spring cycles.  So added the gold lines (as well as a little bit extra for coilovers).
Drilled holes and transferred to the inside where cutting would be easier:
And no turning back now:
Starting CAD'ing some shock towers, but ran out of cardboard after I screwed up the first template.  Oh well, boss was notifying me that OT wasn't approved and went inside for chow.
Damn homie, gettin' after it!
Measure 4x...
While you’re at it may as well just 4 link it. Leafs are for trees.
Meh.  I would, but got delayed because my buggy decided to shit out all the parts I transferred over from the old chassis and kept working on it instead.  Doing a 3-link up front though.
Halfway there. EE70A0CF-94EA-4AB4-9006-29AF8BE47852.thumb.jpeg.67a13a3dcbad55bcb38a45cf6afc6280.jpeg
Btw: I really hate welding to the stock steel.
And done...
Lost a little trunk space
And re-bumpstopped  it so the tires don’t munch on the fenders like a lesbian on short carpet
Lots of droop
Nice work!  I gotta step-up and get a welder and start practicing on scrap.  It would be so nice to be able to take on projects like that myself.  Random quick question, how often do you find you use the little fold-out table on your spare tire carrier?  I'm debating that option on the bumper/tire carrier I'm considering:  https://www.xerofabworx.com/wj-rear-bumper-tire-carrier-p/wj-rearbumper.htm
-TJ
