JM PRO
Need help cutting paddles off paddle tire
GD.COM
I need some help! I just bought some brand new Extreme paddles with all 36 paddles still on the tire. I need to cut off 18 of the paddles. I tried the oscillating tool with no success and I bought the KnobbyKnife tire groover and that didn't work for crap. Fullerton Sand tires is now closed and I called Pro Wheels who bought them out and they cannot do it. I have called Extreme and they wont cut them. I've called Kartek, Mckenzies and Skat Trak and all said no. Who can cut them and get factory quality cuts???
You can buy an iron and DIY.
The is a guy in Utah called the @tiretuner on Instagram who might do it
also Kartek uses a guy to cut all there tires
Dune Land in Michigan is who is doing the most paddle cutting around
use a sawzall with the teeth ground down on blade to make it like a razor blade. Put propane heater on  tire to warm the rubber. It cuts like butter.
Did you find someone to cut your paddles @JM PRO?Came across some paddle at a good deal on some extreme with all the paddles in az  area. Weighing cost of removing paddles to see if it worth the trouble. Thanks!
