ElCaminoManT Posted March 16 Share Posted March 16 Buddy of mine is selling his truck camper. Have a look! Located in Mt Helix/El Cajon 2018 Arctic Fox 811 truck camper. -True 4 seasons all weather camper, extremely well insulated! -Aluminum framed superstructure. -Full walk-on crowned roof with roof storage rack. -Dual ram slide-out room with dinette. -Dinette converts into 43"x76" bed. -Queen bed in cabover. -Heated holding tanks. -50 gallons fresh water tank, 38 gallons gray water holding tank, 23 gallons black water holding tank. -6 gallon DSI propane water heater with 110v electric function as well. -(2) 30lb propane tanks with auto switch-over valve. -Propane quick-connect at rear bumper for bbq grille. -(2) deep cycle 12V batteries on sliding tray. -LED lighting inside and out. -Fantastic fan roof vent above bed. -Vent covers over both roof vents. -Power Carefree patio awning. -Power jacks. -Flip out front jack brackets to clear dually fenders. -Jacks, slide out room and awning can all be controlled via remote control. -Stainless kitchen sink has been converted from split bowl to large single bowl. -Large pull-out storage tray under entry door. -11K BTU roof air conditioner. -20K BTU furnace. -20W solar panel on roof. -6 CU FT gas/electric refrigerator with stainless look panels -Stainless 3-burner stove with oven and hood. -Stainless microwave. -Pleated pull-down shades on all windows and skylight. -Tons of storage throughout incl a large pull-out pantry. -19" 12v LCD TV on swing arm. Factory installed options: -Thermal pane windows with pleated pull-down shades. -On-board Onan 2500LP generator. -Wireless backup camera system. -Fox Landing folding deck/step combination. -Additional 100W solar panel on roof with interior controller plus external plug to add a portable panel. Additionally: -Upgraded "RV Lock" key pad door lock with (2) keys and (2) remotes. -Upgraded MB Quart stereo/DVD player (also have original Kenwood unit if desired) **The 811 is designed for standard bed pickup however it will fit long bed as well with room in front for a small tool box if desired as seen in the pictures. -Purchased new from Norm's RV in Poway and has been stored in San Diego. Asking $30,900 **Also available as possible combo purchase for $90,000: -2018 Chevrolet Silverado 3500HD 4x4 Dually that is setup to haul a slide-in camper. -Only 15,130 miles!!! -LY5 Duramax Diesel. -6 Speed Allison transmission -LTZ trim with appearance package. -Leather interior with heated and ventilated seats. -Bose sound system. -Alloy wheels with Michelin tires. -Tubular side steps. -Rubber bed mat. -TorkLift frame mounted tie downs for camper. -TorkLift SuperHitch 20K lbs double stack receiver hitch. -Hellwig rear sway bar. -Airlift air helper springs. -On board air system with Viair compressor, air tank and quick connect fittings in both rear wheel wells. *****will not sell truck before the camper sells***** Call/Text Tony @ (858)722-0987 1 Quote Link to comment Share on other sites More sharing options...
ElCaminoManT Posted Friday at 06:09 PM Author Share Posted Friday at 06:09 PM Quote Link to comment Share on other sites More sharing options...
Site Sponsor Kraut_n_Rice Posted Tuesday at 01:32 AM Site Sponsor Share Posted Tuesday at 01:32 AM Very nice. Quote Link to comment Share on other sites More sharing options...
