Sign in to follow this
Oldman
Wheel And Rim Chart For Quads And Side X Sides
Wow that is an awsome site !
Looks like it will work...
thanks oldman
This may help.
ATV Tire and Wheel Application Chart
How to read the chart:
Tire Example:
25 x 10 x 12
· Tire Diameter = 25"
· Tire Width = 10"
· Rim Diameter = 12"
Wheel Example:
10 x 8 3+5 4/110
Wheel Diameter = 10"
Wheel Width = 8"
Wheel Offset = 3" mounting centerline to inside wheel edge and 5" mounting center line to the outside wheel edge
Number of Bolt Holes = 4
Spacing of bolt holes = 110" (measured from center of one bolt hole across center of wheel to opposite bolt hole)
Note: Most OEM Wheel Applications have no offset (the wheel is centered over the hub). In these cases, the wheel offset is omitted from the listing.
Still can't find your bolt pattern?
Most of the bolt applications are in millimeters. You can determine your bolt pattern by measuring from the center of one wheel stud to the center of the opposing wheel stud across the hub.
Next, determine your correct bolt pattern. Convert your measurement from inches to millimeters by multiplying by 25.4. It's that simple.
Example:
Wheel stud measurement: 4-5/16" = (4.313")
Formula:
4.313 x 25.4 = 109.6 mm ==> 110mm bolt pattern
ARCTIC CAT
OEM TIRE SIZE
OEM WHEEL SIZE
250 2WD/4WD, 99-03 (F)
23x8x12
12x7, 4/115
250 2WD, 99 ®
25x10x12
12x7, 4/115
250 2WD, 00 ®
24x9x12
12x7, 4/115
250 2WD/4WD, 01 ®
23x10x12
12x7, 4/115
250 2WD/4WD, 02-03 ®
24x9x12
12x7, 4/115
300 2WD, 98-03 (F)
23x8x12
12x7, 4/115
300 4WD, 98-00 (F)
24x9x12
12x7, 4/115
300 4WD, 01 (F)
23x8x12
12x7, 4/115
300 2WD/4WD, 98-00 ®
25x10x12
12x7, 4/115
300 2WD/4WD, 01 ®
23x10x12
12x7, 4/115
300 4WD, 02-03 (F)
24x9x12
12x7, 4/115
300 2WD/4WD, 02-03 ®
25x10x12
12x7, 4/115
375 2WD/4WD, 02-03 (F)
25x8x12
12x7, 4/115
375 2WD/4WD, 02-03 ®
25x10x12
12x7, 4/115
400 2WD/4WD, 98-03 (F)
25x8x12
12x7, 4/115
400 2WD/4WD, 98-03 ®
25x10x12
12x7, 4/115
400i 2WD/4WD, 02-04 (F)
25x8x12
12x7, 4/115
400i 2WD/4WD, 02-04 ®
25x11x12
12x7, 4/115
454 2WD/4WD, 96-98 (F)
25x8x12
12x7, 4/115
454 2WD/4WD, 96-98 ®
25x10x12
12x7, 4/115
500 4WD, 98-99 (F)
26x10.5x12
12x7, 4/115
500 4WD, 98-99 ®
26x10.5x12
12x7, 4/115
500 4WD, 00-03 (F)
25x8x12
12x7, 4/115
500 4WD, 00-03 ®
25x10x12
12x7, 4/115
500i 4WDi, 02-04 (F)
25x8x12
12x7, 4/115
500i 4WDi, 02-04 ®
25x11x12
12x7, 4/115
600i 4WDi, 2004 (F)
26x8x12
12x7, 4/115
600i 4WDi, 2004 ®
26x11x12
12x7, 4/115
BOMBARDIER
OEM TIRE SIZE
OEM WHEEL SIZE
Outlander 330-400 2WD/4WD, 03-04 (F)
25x8x12
12x7, 4/137
Outlander 330-400 2WD/4WD, 03-04 ®
25x10x12
12x7, 4/137
Traxter 500 4WD, 99-04 (F)
25x8x12
12x7, 4/110
Traxter 500 4WD, 99-04 ®
25x10x12
12x7, 4/110
Quest 500-650, 00-04 (F)
25x8x12
12x7, 4/110
Quest 500-650, 00-04 ®
25x10x12
12x7, 4/110
DS 650, 00-04 (F)
21x7x10
10x5, 4/143
DS 650, 00-04 ®
20x11x9
9x9, 4/143
HONDA
OEM TIRE SIZE
OEM WHEEL SIZE
TRX 70, 86-87 (F)
16x8x7
7x6, 4/110
TRX 70, 86-87 ®
16x8x7
7x6, 3/100
TRX 90, 93-03 (F)
20x7x8
8x5.5, 4/85
TRX 90, 93-03 ®
19x8x8
8x6.5, 4/85
ATC 90/110, Thru 81 ®
22x11x8
8x8, 3/100
ATC 110/125/125M, 82-87 ®
22x11x8
8x8, 4/130
TRX 125, 87-88 (F)
20x7x8
8x6, 4/85
TRX 125, 85-88 ®
22x10x8
8x8, 4/130
ATC 185S, Thru 81 ®
22x11x8
8x8, 3/100
ATC 185S, 82-84 ®
22x11x8
8x8, 4/130
ATC 185/200/Big Red, 80-84 ®
25x12x9
9x9, 4/150
ATC 200S, 84/85 ®
22x11x8
8x8, 4/130
ATC 200M, Thru 85 ®
25x12x9
9x9, 4/150
ATC 200X, 83-85 ®
22x11x8
8x8, 4/110
ATC 200X, 86-87 ®
22x10x9
9x9, 4/110
TRX 200, 90-93, 96-97 (F)
21x7x10
10x5, 4/110
TRX 200, 90-93, 96-97 ®
22x10x8
8x8, 4/110
TRX 200, 84 ®
25x12x9
9x9, 4/150
TRX 200SX, 86-88 ®
22x11x8
8x8, 4/110
ATC 250 Big Red, 85 ®
25x12x9
9x9, 4/110
TRX 250 Big Red, 86-87 (F)
21x7x10
10x5, 4/110
TRX 250 Big Red, 85-87 ®
25x12x9
9x9, 4/110
ATC 250SX, 85-87 ®
22x11x8
8x9, 4/110
ATC 250R, 81 ®
22x11x8
8x8, 3/100
ATC 250R, 82 ®
22x11x8
8x8, 4/130
ATC 250R, 83-84 ®
22x11x8
8x8, 4/110
ATC 250R, 85-86 ®
20x10x9
9x9, 4/110
TRX 250R, 86-89 (F)
22x7x10
10x5, 4/144
TRX 250R, 86-89 ®
20x10x9
9x9, 4/110
TRX 250X, 86-87 (F)
22x7x10
10x5, 4/110
TRX 250X, 88, 90-92 (F)
22x7x10
10x5, 4/144
TRX 250X, 86-92 ®
20x10x9
9x9, 4/110
TRX 250 RECON, 97-04 (F)
22x7x11
11x7, 4/110
TRX 250 RECON, 97-04 ®
22x10x9
9x9, 4/110
TRX 250EX, 00-04 (F)
22x7x11
10x5, 4/144
TRX 250EX, 00-04 ®
22x10x9
9x9, 4/110
TRX 300EX, 93-04 (F)
22x7x10
10x5, 4/144
TRX 300EX, 93-04 ®
20x10x9
9x9, 4/110
ATC 350X, 85-86 ®
22x11x9
9x9, 4/110
TRX 300 2WD, 88-92 (F)
23x8x11
11x7, 4/110
TRX 300 2WD, 93-00 (F)
23x8x11
11x7, 4/110
TRX 300 2WD, 88-00 ®
25x12x9
9x9, 4/110
TRX 300 4WD, 88-00 (F)
23x8x11
11x7, 4/110
TRX 300 4WD, 88-00 ®
24x9x11
11x7, 4/110
TRX 350 4WD, 86-92 (F)
24x9x11
11x7, 4/110
TRX 350 4WD, 86-92 ®
24x9x11
11x7, 4/110
TRX 350 Rancher S-ES 2WD 00-04 (F)
24x8x12
12x7, 4/110
TRX 350 Rancher S-ES 2WD 00-04 ®
25x11x10
10x8, 4/110
TRX 350 Rancher S-ES 4WD 00-04 (F)
24x8x12
12x7, 4/110
TRX 350 Rancher S-ES 4WD 00-04 ®
24x9x11
11x7, 4/110
TRX 400 Rancher AT 4WD, 04 (F)
24x8x12
12x7, 4/110
TRX 400 Rancher AT 4WD, 04 ®
24x10x11
11x7, 4/110
TRX 400EX, 99-04 (F)
22x7x10
10x5, 4/144
TRX 400EX, 99-04 ®
20x10x9
9x9, 4/110
TRX 400 Foreman 4WD, 96-04 (F)
24x8x11
11x7, 4/110
TRX 400 Foreman 4WD, 96-04 ®
24x10x11
11x7, 4/110
TRX 450 Foreman S-ES 4WD, 98-04 (F)
25x8x12
12x7, 4/110
TRX 450 Foreman S-ES 4WD, 98-04 ®
25x10x12
12x7, 4/110
TRX 500 Rubicon 4WD, 01-04 (F)
25x8x12
12x7, 4/110
TRX 500 Rubicon 4WD, 01-04 ®
25x10x12
12x7, 4/110
ODYSSEY, 77-81 (F)
20x7x8
8x5, 3/100
ODYSSEY, 77-81 ®
22x11x8
8x8, 3/100
ODYSSEY, 82-84 ®
22x11x8
8x8, 4/130
ODYSSEY, 85-86 (F)
21x7x10
10x5, 4/110
ODYSSEY, 85-86 ®
24x11x10
10x8, 4/130
PILOT, 89-90 (F)
21x7x10
10x5, 4/110
PILOT, 89-90 ®
24x11x10
10x8, 4/130
KAWASAKI
OEM TIRE SIZE
OEM WHEEL SIZE
KLT 110/160/185/200, All ®
21x9x8
8x8, 4/4
KLF 185 Bayou, 85-87 ®
22x11x8
8x8, 4/110
KLF 220 Bayou, 88-02 (F)
22x8x9
9x6, N/A
KLF 220 Bayou, 88-02 ®
22x10x10
10x8, 4/137
KLT 250, 82-85 ®
25x12x9
9x9, 4/4
KXT 250 Tecate, 84 ®
22x11x10
10x8, 4/4
KXT 250 Tecate, 85-87 ®
22x11x10
10x8, 4/156
KXT 250 Tecate-4, 87-88 (F)
21x7x10
10x5, 4/156
KXT 250 Tecate-4, 87-88 ®
22x11x10
10x8, 4/156
KSF 250 Mojave, 87-03 (F)
21x7x10
10x5, 4/156
KSF 250 Mojave, 87-03 ®
22x11x10
10x8, 4/156
KLF 300 Bayou 2WD, 85-03 (F)
22x9x10
10x6, 4/137
KLF 300 Bayou 2WD, 85-03 ®
24x11x10
10x8, 4/137
KLF 300B Lakota, 95-00 (F)
22x8x10
10x5, 4/156
KLF 300B Lakota, 95-00 ®
22x11x10
10x8, 4/156
KLF 300 Bayou 4WD, 89-03 (F)
24x8x11
11x6, 4/137
KLF 300 Bayou 4WD, 89-03 ®
24x10x11
11x7, 4/137
Prairie 300 2WD/4WD, 99-03 (F)
25x8x12
12x7, 4/137
Prairie 300 2WD, 99-03 ®
25x11x10
10x8, 4/137
Prairie 300 4WD, 99-03 ®
25x11x10
10x8, 4/137
Prairie 360 2WD, 03 (F)
25x8x12
12x7, 4/137
Prairie 360 2WD, 03 ®
25x10x12
12x7, 4/137
Prairie 360 4WD, 03 (F)
25x8x12
12x7, 4/137
Prairie 360 4WD, 03 ®
25x10x12
12x7, 4/137
KLF 400 Bayou 4WD, 93-03 (F)
24x8x11
11x6, 4/137
KLF 400 Bayou 4WD, 93-03 ®
24x10x11
11x7, 4/137
Prairie 400 2WD/4WD, 97-03 (F)
25x8x12
12x7, 4/137
Prairie 400 2WD/4WD, 97-03 ®
25x12x10
10x8, 4/137
KFX 400 2WD, 03 (F)
22x7x10
10x5, 4/144
KFX 400 2WD, 03 ®
20x10x9
9x9, 4/110
Prairie 650 4WD, 02-03 (F)
25x8x12
12x7, 4/137
Prairie 650 4WD, 02-03 ®
25x10x12
12x7, 4/137
Prairie 700 4WD, 04 (F)
25x8x12
12x7, 4/137
Prairie 700 4WD, 04 ®
25x10x12
12x7, 4/137
KFX 700 2WD, 03-04 (F)
22x7x10
10x5, 4/144
KFX 700 2WD, 03-04 ®
22x11x10
10x8, 4/137
Mule 500 (F)
22x9x10
10x7, 4/137
Mule 500 ®
22x11x10
10x8, 4/137
Mule 1000/2000/2510 (F&R)
22x11x10
10x8, 4/137
Mule 3000 (F&R)
23x11x10
10x8, 4/137
SUZUKI
OEM TIRE SIZE
OEM WHEEL SIZE
LT 50, 86-87 (F&R)
145/70-60
6x6, 3/90
LT 80 Quadsport, 87-03 (F)
19x7x8
8x6, 3/120
LT 80 Quadsport, 87-03 ®
19x7x8
8x6, 3/120
LT/ALT 125, 83 ®
22x11x8
8x8, 3/100
LT/ALT 125F, 84-87 ®
22x11x8
8x8, 4/130
LT 160 Quadrunner, 89-02 (F)
20x7x8
8x6, 4/112
LT 160 Quadrunner, 89-02 ®
22x10x8
8x8, 4/112
LT 185 Quadrunner, 83 ®
22x11x8
8x8, 4/130
LT/ALT 185, 84-87 ®
22x11x8
8x8, 4/130
LT 230 GEG Quadrunner, 85-86 ®
22x11x8
8x8, 4/130
LT 230 GEF Quadrunner, 85-87 ®
22x11x9
9x9, 4/130
LT 230 EH/EJ/EK Quadrunner, 87 ®
22x11x9
9x9, 4/130
LT 230 EH/EJ/EK, 87-89, 91-93 (F)
21x7x10
10x5, 4/166
LT 230 EH/EJ/EK, 88-89, 91-93 ®
22x11x9
9x9, 5/130
LT 230 QuadSport, 85-88 (F)
21x7x10
10x5, 4/166
LT 230 QuadSport, 85-88 ®
22x11x9
9x9, 4/130
LT 250 QuadSport, 89-90 (F)
21x7x10
10x5, 4/166
LT 250 QuadSport, 89-90 ®
22x11x9
9x9, 4/130
LT 250F Quadrunner, 89-02 (F)
22x8x10
10x5, 4/140
LT 250F Quadrunner, 89-02 ®
24x11x10
10x8, 4/140
LT 250E/F/G Quadrunner, 84-86 ®
22x11x9
9x9, 4/130
LT 300 E Quadrunner, 87-90 (F)
21x8x9
9x6, 4/130
LT 300 EH Quadrunner, 87-88 ®
25x12x9
9x9, 4/130
LT 300 EJ Quadrunner, 89-90 ®
25x12x9
9x9, 5/130
LT 250R QuadRacer, 85-92 (F)
21x7x10
10x5, 4/166
LT 250R QuadRacer, 85-86 ®
22x11x10
10x8, 4/130
LT 250R QuadRacer, 87-92 ®
22x10x10
10x8, 5/130
LT 250 4WD, 88-02(F)
22x8x10
10x5, 4/140
LT 250 4WD, 88-02 ®
24x11x10
10x8, 4/140
Z250 2WD, 02-03 (F)
22x7x10
10x5, 4/144
Z250 2WD, 02-03 ®
20x10x9
9x9, 4/110
OZARK 250 2WD, 02-03 (F)
22x7x11
11x7, 4/110
OZARK 250 2WD, 02-03 ®
20x10x9
9x9, 4/110
LT 300 4WD XM King Quad, 91-03 (F)
24x8x11
11x6, 4/140
LT 300 4WD XM King Quad, 91-03 ®
25x10x12
12x7, 5/160
Eiger 400 2WD, 02-03 (F)
25x8x12
12x7, 4/110
Eiger 400 2WD, 02-03 ®
25x12x12
12x7, 4/110
Eiger 400 Auto 2WD, 02-03 (F)
25x8x12
12x7, 4/110
Eiger 400 Auto 2WD, 02-03 ®
25x12x12
12x7, 4/110
Eiger 400 4WD, 02-03 (F)
25x8x12
12x7, 4/110
Eiger 400 4WD, 02-03 ®
25x12x12
12x7, 4/110
Eiger 400 Auto 4WD, 02-03 (F)
25x8x12
12x7, 4/110
Eiger 400 Auto 4WD, 02-03 ®
25x12x12
12x7, 4/110
LT 500R QuadRacer, 87-90 (F)
21x7x10
10x5, 4/166
LT 500R QuadRacer, 87-90 ®
22x11x10
10x8, 5/130
LT-F/LT-A 500 Quadrunner, 98-02 (F)
25x8x12
12x7, 4/90
LT-F/LT-A 500 Quadrunner, 98-02 ®
25x10x12
12x8, 4/90
LT-Z400 Quadsport, 02-03 (F)
21x7x10
10x5, 4/144
LT-Z400 Quadsport 02-03 ®
20x11x10
9x9, 4/110
Vinson 500 4x4 02-03 (F)
25x8x12
12x7, 4/110
Vinson 500 4x4 02-03 ®
25x10x12
12x7, 4/110
POLARIS
OEM TIRE SIZE
OEM WHEEL SIZE
Trail Boss/Cyclone/Trail Blazer, 86-02 (F)
23x7x10
10x5, 4/156
Trail Boss/Cyclone/Trail Blazer, 86-02 ®
22x11x10
10x8, 4/4
Trail Boss 4x4 250/300, 87-95 (F)
23x7x10
10x5, 4/156
Trail Boss 4x4 250/300, 87-95 ®
22x11x10
10x8, 4/4
Xplorer 300/Trail Boss 2x4 350L/400L, 90-99 (F)
23x7x10
10x5, 4/156
Xplorer 300/Trail Boss 2x4 350L/400L, 90-99 ®
24x11x10
10x8, 4/4
Magnum 325 2x4/4x4, 00-02 (F)
24x8x12
12x7, 4/156
Magnum 325 2x4/4x4, 00-01 ®
24x11x10
10x8, 4/4
Magnum 325 2x4/4x4, 2002 ®
24x11x10
10x8, 4/156
Xpedition 325 4x4, 00-02 (F)
24x8x12
12x7, 4/156
Xpedition 325 4x4, 00-02 ®
24x11x10
10x8, 4/4
Sportsman 335 4x4, 99-01 (F)
23x7x10
10x5, 4/156
Sportsman 335 4x4, 99-01 ®
24x11x10
10x8, 4/156
Trail Boss 4x4 350L/400L, 90-94 (F)
25x8x12
12x7, 4/156
Trail Boss 4x4 350L/400L, 90-94 ®
25x12x10
10x8, 4/4
Sportsman 400/Magnum 4x4 425L,95-98 (F)
25x8x12
12x7, 4/156
Sportsman 400/Magnum 4x4 425L,95-98 ®
25x11x10
10x8, 4/4
Sportsman 400 4x4 425L,01-02 (F)
25x8x12
12x7, 4/156
Sportsman 400 4x4 425L,01-02 ®
25x11x10
10x8, 4/156
Magnum 2x4/Xpress 300/400L, 96-99 (F)
23x7x10
10x5, 4/156
Magnum 2x4/Xpress 300/400L, 96-99 ®
24x11x10
10x8, 4/4
Xplorer 4x4 400L, 95-01 (F)
25x8x12
12x7, 4/156
Xplorer 4x4 400L, 95-01 ®
25x12x10
10x8, 4/4
Scrambler 2x4/4x4 400L, 95-01 (F)
23x7x10
10x5, 4/156
Scrambler 2x4/4x4 400L, 95-01 ®
22x11x10
10x8, 4/4
Sport 400L 2x4, 94-99 (F)
23x7x10
10x5, 4/156
Sport 400L 2x4, 94-99 ®
22x11x10
10x8, 4/4
Xpedition 425 4x4, 99-01 (F)
25x8x12
12x7, 4/156
Xpedition 425 4x4, 99-01 ®
25x11x10
10x8, 4/4
Xplorer/Sportsman 500 4x4, 96-01 (F)
25x8x12
12x7, 4/156
Xplorer/Sportsman 500 4x4, 96-01 ®
25x11x10
10x8, 4/156
Magnum 500 4x4, 99-03 (F)
25x8x12
12x7, 4/156
Magnum 500 4x4, 99-03 ®
25x11x10
10x8, 4/4
Scrambler 500 2x4/4x4, 97-03 (F)
23x7x10
10x5, 4/156
Scrambler 500 2x4/4x4, 97-03 ®
22x11x10
10x8, 4/4
Predator 500 2x4, 03-04 (F)
21x7x10
10x8, 4/156
Predator 500 2x4, 03 ®
20x11x10
10x8, 4/156
Predator 500 2x4, 04 ®
20x11x10
10x8, 4/110
Sportsman 600 4x4, 03 (F)
25x8x12
12x7, 4/156
Sportsman 600 4x4, 03 ®
25x11x12
12x7, 4/156
Sportsman 700 4x4, 02-03 (F)
25x8x12
12x7, 4/156
Sportsman 700 4x4, 02-03 ®
25x10x12
12x7, 4/156
Diesel 4x4, 99-01 (F)
25x8x12
12x7, 4/156
Diesel 4x4, 99-01 ®
25x11x10
10x8, 4/156
Big Boss 4x6, 89-94 (F)
22x8x10
10x5, 4/156
Big Boss 4x6, 89-94 ®
22x11x10
10x8, 4/4
Magnum/Big Boss 6x6, 93-01 (F)
25x8x12
12x7, 4/156
Magnum/Big Boss 6x6, 93-01 ®
25x12x10
10x8, 4/4
Ranger, 98-01 (F)
25x10x12
12x7, 4/156
Ranger, 98-01 ®
25x11x10
10x8, 4/156
YAMAHA
OEM TIRE SIZE
OEM WHEEL SIZE
YF 60 Zinger, All years (F&R)
15x7x6
6x6, 3/70
YFM 80E Badger, 93-04 (F)
18x7x7
7x6, N/A
YFM 80E Badger, 93-04 ®
20x9x8
8x8, N/A
YFM 80 Moto-4, 87-92 ®
19x8x7
7x6, 3/70
YFM 100T Moto-4, 87-90 ®
20x9x8
8x8, 4/100
YFA 125 Breeze, 89-02 (F)
20x7x8
8x7, 4/85 LB
YFA 125 Breeze, 89-02 ®
22x10x8
8x8, 4/85
YT 125/175 Tri-Moto, 81-85 ®
22x11x8
8x8, 3/100
YTM 200 E/L/R Tri-Moto, 83/86 ®
25x12x9
9x10, 4/125
YTM 200 DX, 88-90 (F)
22x8x10
10x5, 4/156
YTM 200 DX, 88-90 ®
22x11x8
8x8, 4/100
YSF 200 U Blaster, 88-04 (F)
21x7x10
10x5, 4/156
YSF 200 U Blaster, 88-04 ®
21x10x8
8x8, 4/100
YTM 225 DX/DR Tri-Moto ®
22x11x8
8x8, 3/100
YFM 225 Moto-4, 85-87 (F)
22x8x10
10x5, 4/156
YFM 225 Moto-4, 85-87 ®
25x12x9
9x9, 4/125
YFM 250 Moto-4, 89 (F)
22x8x10
10x6, 4/110
YFM 250 Moto-4, 89 ®
25x12x9
9x9, 4/110
YFB 250 Timberwolf 2x4, 92-94 (F)
22x7x10
10x5, 4/156
YFB 250 Timberwolf 2x4, 95-98 (F)
22x7x10
10x5, 4/110
YFB 250 Timberwolf 2x4, 92-98 ®
22x11x10
10x8, 4/110
Bear Tracker 250, 99-02 (F)
22x7x10
10x5, 4/110
Bear Tracker 250, 99-02 ®
22x10x10
10x8, 4/110
YFB 250 Timberwolf 4x4, 95-04 (F)
23x8x10
10x5, 4/110
YFB 250 Timberwolf 4x4, 95-04 ®
23x10x10
10x8, 4/110
YTZ 250 Tri-Z, 85 ®
22x11x8
8x8, 4/100
YTZ 250 Tri-Z, 86 ®
22x11x9
9x8, 4/100
YFM 350 XT Warrior, 87-04 (F)
22x7x10
10x5, 4/156
YFM 350 XT Warrior, 87-04 ®
22x10x9
9x9, 4/115
YFM 350 Wolverine, 95-04 (F)
23x8x12
12x7, 4/110
YFM 350 Wolverine, 95-04 ®
23x10x12
12x7, 4/110
YFZ 350 T Banshee, 87-04 (F)
21x7x10
10x5, 4/156
YFZ 350 T Banshee, 87-88, 91-04 ®
22x10x9
9x9, 4/115
YFZ 350 T Banshee, 89-90 ®
22x11x10
10x8, 4/156
YFM 350 ER Moto-4, 87-88 (F)
22x8x10
10x5, 4/156
YFM 350 ER Moto-4, 89-95 (F)
22x8x10
10x5, 4/110
YFM 350 ER Moto-4, 87-92 ®
25x12x9
9x9, 4/125
YFM 350 ER Moto-4, 93-95 ®
25x12x9
9x9, 4/110
YFM 350 Big Bear 2WD, 96-04 (F)
25x8x12
12x7, 4/110
YFM 350 Big Bear 2WD, 96-99 ®
25x12x9
9x9, 4/110
YFM 350 Big Bear 2WD, 00-04 ®
23x10x10
10x8, 4/110
YFM 350/400 Big Bear 4WD, 87-03 (F)
25x8x12
12x7, 4/110
YFM 350/400 Big Bear 4WD, 87-03 ®
25x10x12
12x7, 4/110
YFM 400 Kodiak 4WD, 93-04 (F)
25x8x12
12x7, 4/110
YFM 400 Kodiak 4WD, 93-04 ®
25x10x12
12x7, 4/110
YFM 400 Kodiak 2WD, 93-04 (F)
25x8x12
12x7, 4/110
YFM 400 Kodiak 2WD, 93-04 ®
25x10x12
12x7, 4/110
YFZ 450 2WD, 04 (F)
21x7x10
10x5, 4/156
YFZ 450 2WD, 04 ®
20x10x9
9x9, 4/115
YFM 600 Grizzly, 98 (F)
25x8x12
12x7, 4/110
YFM 600 Grizzly, 98 ®
25x10x10
10x8, 4/110
YFM 600 Grizzly, 99-01 (F)
25x8x12
12x7, 4/110
YFM 600 Grizzly, 99-00 ®
25x10x12
12x7, 4/110
YFM 600 Grizzly, 01 ®
25x10x10
10x8,4/110
YFM 660R Raptor, 01-04 (F)
21x7x10
10x5, 4/156
YFM 660R Raptor, 01-04 ®
20x10x9
9x9, 4/115
YFM 660 Grizzly, 02-04 (F)
25x8x12
12x7, 4/110
YFM 660 Grizzly, 02-04 ®
25x10x12
12x7, 4/110
YFM 660 Rhino, 04 (F)
25x8x12
12x7, 4/110
YFM 660 Rhino, 04 ®
25x10x12
12x7, 4/110
