Air Tank Size??
Funco4JM
I currently have the Airlift 3P; however, when I go to lift from full deflation, it takes several attempts as the tank depletes by the time the bags are at 35PSI. The setup is a 150PSI compressor with a 2.5-gallon tank. 1/4" hose set up from Funco. What size compressor/tank is everyone else using?
I don't need it to pop up like it's on hydraulics, but having the group wait an extra 5 minutes for me to get to ride height is getting old fast.
Thanks!
Because it looks cool... Why else would you do it?!
Should I just go larger tank to 5gallon or do I need 200PSI as well?
Never seen 200 psi. I think the system shuts off compressor at 150. You can do one large tank but sometimes hard to place in the car. Especially if it’s not a full body car. You could also just add a 2nd 2.5 gallon tank via a single hose. Might be easier to place in car
