If you’re looking for your next badass off-road build, this is it.
I’m selling my custom off-road buggy project – built from the ground up with performance, durability, and fun in mind. It’s not finished yet, but it’s 90% there and packed with top-tier parts. Would make an awesome dune car, trail ripper, or weekend warrior toy once completed.
Key Features:
What It Still Needs:
This isn’t a backyard go-kart – it’s a serious off-road machine with all the right parts. If you’ve got the skill to finish it, you’ll have a killer buggy without having to start from scratch.
Asking: $5,000
Call or Text [Your Name] at [Your Number]
No lowballers. No dreamers. If the ad is up, it’s still available. Bring a trailer – and a little vision.
Located in [Your City]
Open to trades for dirt bikes, side-by-sides, ATVs, or other off-road toys.
Call (602)-269-1444
Key Features:
- Kawasaki Ninja 600 Motor (Carbureted) – Sportbike engine with under 800 miles. Lightweight and high-revving for serious fun.
- Handcrafted Aluminum Body – Lightweight, tough, and built to perform. No cheap panels here.
- Heli-Arc Welded Chromoly Suspension – Built right with strength and precision. Not your average backyard tubing.
- Long-Travel Fox Coil-over Shocks – Smooth articulation and real off-road capability. Tuned for abuse.
- 4-Piston Brake Calipers – Mounted and ready. Strong, reliable braking for high-speed play.
- Set up for 930 CV Micro Stubs – Proven drivetrain setup that can handle big torque and aggressive use.
- Polaris Wheel Bolt Pattern – Makes wheels and hubs easy to source.
- Stainless Steel Gas Tank – No rust, no worries. Built to last and look clean.
- Suspension Seat on Adjustable Slider – Ride hard in comfort with solid support.
- Aluminum Radiator with Electric Fan – Keeps temps down no matter how hot the run gets.
- LED Light Bar – Night runs? Covered.
- Final wiring (ignition, fan, lights)
- Throttle linkage and pedal setup
- Brake lines (calipers already mounted)
- A few small finishing touches – kill switch, minor hardware, etc.
Asking: $5,000
Call (602)-269-1444
