Cookie
- 2,034
Honda mated to a Mendi 2D, Pulled tranny out had it gone thru, just got everything back together, when I started the car and tried to put it in gear it won't (with engine running). Bleed clutch slave as well, getting full pull on the clutch, but it is super soft, not much resistance to it. It looks like I am pulling the engine again, fun times.
Any ideas what it could be, did I put the clutch in wrong (can you)? Is the pressure plate bad?
Any ideas, I will be in the garage starting this process all over............
