J Alper
Site Sponsor
- Apr 30, 2021
- 1,945
- 1,680
No, but it will work on your S4 and S4D and FortinWill this work on my 2D?
Fortin sequential.No, but it will work on your S4 and S4D and Fortin
Flat plate, and comes with a weld on mounting plate,Does it have a positive return?
Can you show a pix of the bottom so I can get an idea of how it mounts? I assume a flat plate?
We use to do a bottom shift, but not real popular, I think the Fortin use a bottom shift, Only doing the to shift like a Albins, so i think for a Fortin the arm on the trans to shift it will have to be reversed,Fortin sequential.![]()
I meant a wide gear 4 speed. Those are H pattern. Fortin offers other transaxles other than the sequential.Flat plate, and comes with a weld on mounting plate,
Moving forward on the Weddle Transaxle they do not want any return springs on the shifters, we have tested ours for about 2 years now, and on the S4D it makes it a much smoother shift,
If a top shift will work then Yes,
On the S4 we move the shifter arm upside down on the new transaxle, and on the old trans we make a plate to move the cable on the opposite side of the shaft, to reverse the shift
Jason has a version that works with PBS. I am super happy with mine
for the mendi mid engine, we still do the top shift and flip the tranny shift arm upside down to change the direction, will post a picture this weekendWill it work for a mid engine? I'm waiting on my new S4 now and I will need a shifter.
We now make a part that bolts onto the trans to put the cable down to make it shift the other direction
