wesinls
- May 6, 2021
- 902
- 1,138
Anyone use these yet? Or have an alternative.\?
Race Ready Products > Cnc Master Cylinder Seal Kits
I tried to rebuild a CNC turning brake master cylinder. The only parts I could find that "might" fit were Empi. Let's just say...they didn't fit and I ended up buying a new Jamar setup.Also see that empi makes a copy of the CNC caliper, they do a lot of junk parts, but they do some quality DOT parts
anyone use a empi master,
Search "3/4 Bore Rectangular master cylinder" on ebay. Change the size to whatever you need. 7/8, etc. You can get the whole damn thing new for a few bucks more. Exact same CNC build. New hardware and boot.Anyone use these yet? Or have an alternative.\?
the EMPI MC's are hit or miss IMOAlso see that empi makes a copy of the CNC caliper, they do a lot of junk parts, but they do some quality DOT parts
I tried the Jmar and the pedal now feels really soft, on both cars we prepped, went to a Tilton and feels the same now as the CNC, but i hate the flip top, because i can not pressure blead it from the cap,the EMPI MC's are hit or miss IMO
I swapped in an Empi turn brake for a CNC and it leaked within a month -
I also swapped an EMPI rectangular MC set for CNC's one was fine, one had a bad check valve during the season
I removed all of it and replaced with Jamar - no more issues
They are Latest Rage, i am a Rage dealer was thinking about getting one and pulling it apartSearch "3/4 Bore Rectangular master cylinder" on ebay. Change the size to whatever you need. 7/8, etc. You can get the whole damn thing new for a few bucks more. Exact same CNC build. New hardware and boot.
I hate the Tilton and wilwood MC's just because I cannot seem to check and fill without getting brake fluid all over as the fluid gets up in the corners and drips - then it has to be a quick clean upI tried the Jmar and the pedal now feels really soft, on both cars we prepped, went to a Tilton and feels the same now as the CNC, but i hate the flip top, because i can not pressure blead it from the cap,
Maybee the Rage housing with the Race Ready seals inside,
The tilton reservoirs I bought are a standard twist cap and I was able to pressure bleed.I tried the Jmar and the pedal now feels really soft, on both cars we prepped, went to a Tilton and feels the same now as the CNC, but i hate the flip top, because i can not pressure blead it from the cap,
The Jamar ones will bolt right up.Can I just swap out to a Jamar MC, or do i need the whole pedal assembly?
Jamar is a direct bolt in replacement master. My CNC clutch master went bad, replaced with a Jamar a few years ago and it's been working fine. The Jamar is a little taller than the CNC.Can I just swap out to a Jamar MC, or do i need the whole pedal assembly?
I have been using this now for coming on 3 seasons. So far so good. I am using it for my clutch.Can I just swap out to a Jamar MC, or do i need the whole pedal assembly?
