Big_Daddy_Jp
- May 6, 2021
- 1,315
- 1,259
I’m a huge stereo nut. I’ve put systems in just about everything I’ve owned. That goes for the new Pro R I just got! This time I decided to give Fosgates kit a try. There was no beating the package I got for the price if I tried as long as it performed. So here is my take on it and I hope it helps if anyone is thinking to add some tunes. I purchased the stage 5 kit. This kit replaces the stock front 6.5’s and tweeters and adds a set of 6.5 coaxials in the rear along with a 12” sub and amp. The stock speakers are 4 ohm. The replacements are 2 ohm along with 2 ohm rear speakers doubling the output of the stock system. Now the stock speakers actually weren’t half bad once the EQ was tuned in as it comes with a flat tune from the dealer. First I installed the rear speakers and replaced the front tweeters just to hear the difference. Believe me it made a huge difference. This alone would probably be enough for most people especially if they could care less about a subwoofer. The instructions for install were very easy to follow and the install was super easy as most was plug and play. The only harness to install was the one for the sub which was very simple as there is already a positive and negative connection for the wiring under the dash. The hardest part of the install was getting the sub under the dash and in place by yourself. Now for the performance of the sub. The sub is lacking at lower volume levels and the amps have no tuning abilities. The other problem is it doesn’t hit low bass notes. The reason I went with the 12” sub was to hit those notes but the box is too shallow for that. Now I can say that it hits hard as the volume goes up and the sound is clean. The factory tuning of the amps seems pretty spot on! The system sounds great with rock and country. The 12” sub has good punch. As I said earlier, hip hop sounds good but lacks when the low notes hit. All in all, very impressed with the clarity, volume, plug and play install, and price point. As a comparison, my other RZR had an Alpine 900 watt 5 channel amp, two sets of 6.5” Fosgate power coaxials, a wet sounds sound bar, and a JL audio 10w3. I bought all of these components and installed them myself using SSV speaker pods and subwoofer box. I had twice as much money into my old system and spent twice as much time installing it all. In the end, the Fosgate stage 5 is louder and more clear and full sounding. Hope this helps!
