Rockwood
- 7,184
96 monthly payments makes it affordable...Hush and sign on the dotted line.
I don’t think that’s going to be a problem. The factory has serious offsets and the paddle tires and wheels only have a 5” offset.How are paddles going to fit in the rear? Spaced outboard more than normal?
I see your 96 and raise you to 120. LOL!96 monthly payments makes it affordable...
Looks like it actually has ground clearance at full bump this time around.
With the fronts, I'd try to keep the offset as close to the upright as reasonable to take advantage of the geometry.I don’t think that’s going to be a problem. The factory has serious offsets and the paddle tires and wheels only have a 5” offset.
HELOC baller it!I see your 96 and raise you to 120. LOL!
Boat loan terms are coming soon with these prices.
This is the @TheLatinLover Edition with Limp Wrist suspension upgrade!
:bag:
@Poule might like this if the arms come in Black!
:lmao:
It's all fun and games until the limp wrists win events...This is the @TheLatinLover Edition with Limp Wrist suspension upgrade!
:bag:
:lmao:
They definitely used a different offset wheel, look how far the tire is from the knuckle, I wonder if that was a necessity to run a 35? In one of the videos, a guy cant even fit his finger between it and the stock tire, This looks like 3" of clearance.35” BFG clearance and looks halfway decent with the aftermarket cage
Noticed the same. Curious how the 35 fits on the stock wheel.They definitely used a different offset wheel, look how far the tire is from the knuckle, I wonder if that was a necessity to run a 35? In one of the videos, a guy cant even fit his finger between it and the stock tire, This looks like 3" of clearance.
My guess is they don't. When they said it fit a BFG 35, this might be how. And now the scrub radius has changed, which was one of the reasons they did this.Noticed the same. Curious how the 35 fits on the stock wheel.
Maybe. It looks like it can easily go in at least a couple of inches, which would put the upper ball joint about on the centerline and the steering axis outside the centerline.My guess is they don't. When they said it fit a BFG 35, this might be how. And now the scrub radius has changed, which was one of the reasons they did this.
The wheel is narrower than the stock can am wheel and that is why there is more clearance on the sidewalk.They definitely used a different offset wheel, look how far the tire is from the knuckle, I wonder if that was a necessity to run a 35? In one of the videos, a guy cant even fit his finger between it and the stock tire, This looks like 3" of clearance.
