SANDBAM
- May 6, 2021
- 250
- 180
1984 rabbit cabriolet
A project car for a guy and his dad and they gave up on it after the dad's health started to really decline
The car is in original condition - lots of good patina - car has sat since 2007
The previous owner started on resurrection and replaced the gas tank - started replacing the fuel pump
I finished the pump install and installed a new fuel filter - added a new battery
gave it a shot turned the key and the car immediately started right away at a higher idle - (false hope)
I found the alternator wasn’t charging and the water pump was leaking , so replaced those and while in there, replaced the coolant hoses and timing belt and drive belt
All timing marks including distributor are properly lined up - I started it up again and it’s just not happy - running very rich
I replaced spark plugs, plug wires, distributor cap, rotor and still not happy - it runs and revs up ok but not just happy at idle - and won’t idle
I brought it to a VW mechanic here in town (AZ) for review of my work - he found that timing marks are lined up and set correctly
He mentioned fuel or ignition as possible next steps - I thought clean the Injectors ? He also said he doesn't have time and room in his shop to go down the Rabbit hole - literally - and said it can get expensive to trouble shoot - I agreed fully
I’m out of ideas - and figured I’d reach out for what anyone here might know about these cars -
there are a bunch of forums out there, but don't also room in garage as the Funco is about back from powder coat
So, what to do - fix it, sell it or swap the current motor with a 1993- 1999 MK3 GOLF RABBIT motor - reading this is the go-to motor for replacement - not super expensive and can get harness to adapt to this early style MK1 rabbit
