Jason,
Weddle clutch assemblies are made by Centerforce, but they are not the same as what you purchase from Centerforce. These have our ideas and designs integrated into them to help them last as long as possible in an off-road car, where many other high performance street clutch packages have proven to be unreliable over the years. We know because we have sold them all.
Our Weddle 9" clutch packages were produced to offer a better product over the common KEP units that leave a lot on the table in terms of new technology and operation. Our friction material allows for a little more forgiveness and does not grab quite as abruptly at the KEP discs.
Our pressure plates use the Centerforce centrifugal weight system that allows for a lighter hold, softer pedal pressure at idle RPM, as the engine spins up in RPM, the spring pressure on the discs increases for more hold. Our pressure plates feel closer to a KEP stage 3 at idle RPM, but will increase to more than a stage 4 holding pressure at higher RPM.
The discs also have sprung hubs to help alleviate the shock loads on the back of the engine, and to the input shaft of the trans. This helps components on both sides of the clutch to live just a little longer. These springs will eventually wear down and start to loosen/rattle with use. We have done just about all that we can to get as much life into these springs as we can with the available space we have.
We have customers that put 10k-15k miles on these clutch's in prerunners. Some guy named Rob Mac uses one in his pre-runner. Look him up, he's somewhat accomplished.
That is not a Weddle disc. We have completely encased our sprung hubs in a steel ring to prevent this sort of failure.
