ChEFF
Forum Moderator
- 10,687
Speaking of getting their cars.....Da chEFF sure needs his to arrive SOON. Peace
So soon we will be flooded with them.Been seeing just about a shipment each week now for a last few weeks.
If not, they should get a full refund for that accessoryHas anyone got their Speed Key yet?
The Speed Key unlocks the 300hp E85 tune. It's a seperate key fob, you use that FOB to start the car, and there is also a rocker switch on the dash. It has to be on E85, or there is zero benefit.could someone explain to me what a speed key is? I assumed it was the key that made it run, but it does not sound like it.
you mean the $1?If not, they should get a full refund for that accessory![]()
The Speed FB groups won't boot anyone.Doesn't seem like anyone has gotten it yet, I asked in the Speed groups.....will report back later, unless I get booted or whatever...
I asked nicely, but you never know haha
thanks. kind of a bummer to order a 300HP car & not get a 300HP car.The Speed Key unlocks the 300hp E85 tune. It's a separate key fob, you use that FOB to start the car, and there is also a rocker switch on the dash. It has to be on E85, or there is zero benefit.
It has an ethanol content sending unit, it tells you all the time what the Ethanol content is. There is nothing stopping you from putting Ethanol in it, but without the key, which unlocks the tune, it does nothing for performance.thanks. kind of a bummer to order a 300HP car & not get a 300HP car.
And even if I dont get the key, what is stopping me from putting E85 into the car? seems like a fuel sending unit would be a good idea (albeit a bit costly).
Heck just "normal gas" has up to 10% of ethanol in it..... I assumed that everyone was ethanol compliant now, this has been going on for years....
60 for a speed or 45 for a maverick R.... I know which one Im buyingDepending on accessories, that's gonna put a price tag of around 60K on those.
The Maverick will the same after you add accessories. Their base price is about the same, except the Maverick is a 2 seater.60 for a speed or 45 for a maverick R.... I know which one Im buying
Always been a 2 seat fan.The Maverick will the same after you add accessories. Their base price is about the same, except the Maverick is a 2 seater.
Did you not order the Speed Key? Even if you don't want it for the desert, for resale value it will be worth a lot.It has an ethanol content sending unit, it tells you all the time what the Ethanol content is. There is nothing stopping you from putting Ethanol in it, but without the key, which unlocks the tune, it does nothing for performance.
Myself, I will never use the 300hp tune, it doesn't need it in the desert.
