We do them almost every day,
The trick is a Big fuel Impact 1/2 fine,
But you will need to heat them up with a MAP gas torch for about a minute to a minute in a half,
This does a couple of things, it will expand the bolt a little and if locktite used it will loosen the locktite,
We have used in the last 15 years - all seals,
The best is the GM Original equipment seal    it will still go out but last a lot longer,  really depends on the car and how the skid plate the balancer style ect...
Every seal we take out that is bad has sand in it,  or if you do not have a oil temp gauge, the upper temps will eat them up easier,
If it is a stock puller then this will work good,
OEMTools 25090 OEM Automotive Tools Harmonic Balancer Puller Sets | Summit Racing
This style puller will not destroy the threads, the shaft will go deep into the crank  ^^^^^^^
INSTALL
I do not like to tap the balancer on and hit it with a impact,   I have done a couple hundred seals  and as tempting as it is,  a couple times in the past, the threads gauled and the bolt had to be broke out and drilled then tapped
Us a cheap good installer,
Summit Racing SUM-900135 Summit Racing™ Harmonic Balancer Installation Tools for GM LS | Summit Racing
This one works good,  but if you do more than about 50 times the bearing goes out,
We use a 12point bolt, if you need one PM us we keep them on the shelft,  or PRW, Speedmaster ARP work the same,
- Factory bolt new - has locktite and sealant on it - so torque to 250lbs and you are good
- Reusing a bolt,  make sure to use silicone on the flange so it does not leak,  and locktite on the threads
- 12PT, use silicone on the under head and on the washer, and locktite on the threads
- Torque all to 250lbs
