Jason Cramer
								So this is me in the Video
1. I wasn’t scared and was doing what I intend to do.
2. I was in 2 gear and 4wd.
3. The car is heavy, which we already Knew.
4. Although the car was slow going up Old’s, once I figured out where I needed to be in the power band I was able to play in the dunes without worry.
5. I did make some air pressure adjustments during the weekend and with the tires I was running I found that a little higher air pressure worked better than a lower pressure. I started at 12 PSI and ended at 14.5.
6. Yes I did expect the car to perform better than it did but this car was designed as a desert car not a sand car, I think with some clutch adjustments it will perform better in the dunes.I didn’t play with the clutch while I was out there. As long as I kept the momentum going, I was able to stay with the Pro R’s in the group.
7. I bought this car knowing that it would have things that I would have to work through. I’m glad to see the Robby and team speed saw the videos, listen to what was going on, and immediately started working on fixing the issue.
