Hi all.. Been a long time since being on this forum. So long, my original login credentials are gone and had to start over...lol
I've seen a few good inverter threads on here. However, I still have a question.
I recently installed a Renogy 2000W Inverter/Charger with built in transfer switch in my Class C. I installed a subpanel and moved only the outlets over and wired the Inverter to the subpanel. That way when the inverter is on, I don't power the Micro, AC, and Converter. Everything works great, except when I'm plugged into shore/generator power, I must have the inverter on to get power to the subpanel/outlets. Some would say, so what... However, I didn't always want the inverter on. I though power would pass through the inverter even it's off.
Question, does this seem to be normal operation? I ask because I had an inverter on my last trailer and it was wired in way that only powered the outlets, however when the plugged in, everything worked and inverter did not need to be on. Unfortunately, I don't know how it was wired. It was all done after the fact...not factory.
I can't think of how to wire this one so that I'm not back feeding the inverter which isn't good...even with the transfer switch. Manual says, don't back feed.
What are your thoughts? TIA..
