ChasingSand
- 758
Motor is a built bottom end J35A4. I have had to have the turbo rebuilt about 4 times now as it continues to leak oil. We have tried almost everything and it continues to leak after each rebuilt. Turbo is a turbonetics TO4B with a -4 Feed.
Performance Tecknique in San Bernadino is doing the rebuilds but have not been able to provide much insight.
Have Tried almost everything and it continues to leak. Had it rebuilt last week and before install, I added a -12 Return and a Turbosmart oil pressure regulator to keep it at 40PSI on the feed line.
Fired it up today and it started leaking within 5 minutes. Tried putting a restrictor on the inlet and did not help at all.
Crankcase vents are clear and I have one -10 off each valve cover.
Also, Oil level when running drops below the return line in the pan.
Anyone experience this before? About to just call it quits at this point.
