jginsandiego
- 290
One bar across the door and weld all the bolt together cage clamp connections is all I thought it was to meet minimum score and best in the desert tech. RG models come with the window nets so if you get an LE you have to buy accessory window nets.IDK if they're available yet (or ever will be) but the idea always was that Speed already had the right bars designed to make the cages fully legal and would sell the kits with the cut/notched tubes to do it. Basically it's things like closing in the door openings and a few other gussets, not a whole re-engineering of the frame. But, I guess it only matters if they run and make enough power to race, right?
-TJ
