Have you ever wondered…
i always heard the fix a flat and other crud in them wheels is rough on aluminum.
I cleaned up the beads on the one on the right side and I think they’ll be just fine for another set of paddles. I will put sta Flo in the tires again to help seal them if necessary.
Did they clean up ok or was the aluminum eaten away?
My .02$
Slime - nasty corrosion
sta-Flo -seemed to flake off and clean up good with a scotch brite pad
I’ll never use slime again unless emergency!!
I had lost a bead out in the dunes, used the brake cleaner trick to reset them, then a decent amount of sta-flo to keep it from leaking since there was sand in the bead.  This was the result, LOL.
