EastMT
- Jul 21, 2022
- 1,011
- 680
Thanks. Another good reason for u-joints. U-joints on both sides of the EPS unit it is.Advantage of u-joints on both sides of unit, forbid that anything happens to cause miss alignment of shaft. Have seen a car wrecked once where shaft then wobbled as it turned. To drive it back to camp, by the time car got there, the shaft had flexed enough to shear off.
I to was skeptical of the egay electronics and bought the controller and bracket from epowersteering.com . The bracket looks well made and better than I would have rigged at home. It has four mounting holes for the eps unit.EPS installs vary quite a bit - but you want to brace the unit very well - so that will partially determine where you put it.
when you say you have all the pieces and its RYO, be careful using e-bay electronics (potentiometer based boards)
Thanks for the good pics and advise!Just did this install for my buddy's son's little 2 seat car. Kept it straight in and out of the EPS
View attachment 118509View attachment 118510
Thanks. I had mine mocked up close like your and thought I should ask before cutting.Picture of how mine ended up. Worked great and never any issues.
