- Thread starter
- #601
ChasingSand
- 882
Looks like an OEM unit which should be fine using a stock pump. I would say maybe try a new aftermarket one from a reputable seller.EastMT was correct about the fan signal. I hooked up a test light to the battery positive terminal and the fan wire. Sure enough the light came on at about 204 degrees when the temperature sensor sent the ground signal. So then I rewired the fan relay to have the ground connected to that wire and started it up again. I have been letting it just idle on it's own without touching the pedal until it gets up to temperature - it is idling at around 1500, no surge. Fans pop on at about 204 degrees. So then I blip the throttle to 3k and the surge starts again. Good to get the fan start up worked out though. I will look for a new sensor that has the fan come on at a little earlier.
The fuel pressure regulator looks like a stock part to me, but it has been relocated from the fuel rail to a block on a bracket (previous owner). The blue fitting is the fuel in line and I don't know what the plastic part is beyond that. The fuel return line seemed small to me, so when I plumbed it back to my tank, I increased the sized of the tube I added. That is something different on the engine from when I bought.... I don't know if that makes a difference on how the fuel pressure regulator performs ??
The other thing that is different that you guys have been pointing me to is the fuel pressure. I'd like to switch fuel pump out for one that does not push as much pressure. Can someone recommend one? J35A4, NA. Thank you all.
Maybe pick up a use OEM one from a wrecking yard tomorrow to see if it changes anything.
