wesinls
- May 6, 2021
- 897
- 1,133
LS3 crate engine tuned by redline and has run flawlessly for 3 seasons. It will cut out at full throttle, back fire violently through exhaust, and after a second or so back to normal. All other throttle positions it runs perfectly.
Cleaned fuel filter, checked wiring, good fuel, good fuel pressure, swapped fuel pumps, good voltage...I'm going to turn on logging on the Holley and read the file when I get home (forgot my cables).
Any thoughts on other things to check? It's a new alternator and I changed out my ignition switch, but given its only at high rpm I can't see how those could be the cause.
