ranman5608
- Jan 23, 2023
- 190
- 263
I have a 2.5 14" coil over and a 3.0 16" bypass on the back of my car. both shocks are set up for 90* at bump. but at full extension un strapped i will use all 16" of the stroke on the BP and only 12" of the stroke on the CO. I have about 5* left in the safe zone on my cvs so more droop is easily accomplished. the bypass is an actual 16" stroke shock. not an 18" de stroked.
so my questions are as follows.
1 can i run an 18" stroke shaft in the 16" shock or will it hit the cap at bump?
2 would removing one of the shaft spacers get me closer or is allowing the piston to travel past the reservoir port a no no.
3 am i wasting my time for an extra 2-3" of droop.
thank you for sharing your wisdom.
