trumanbuckley1
- Jul 21, 2025
- 23
- 20
Hello all, I have recently acquired what I believe to be an old Sand Limo beam car that is a brand new (from the pistons in) turbo 2276 VW that I built. It has an old CB Performance 4 dial fuel injection setup and a locked distributor. It builds boost really slow and doesn't quite seem to have the power I want it to. My current ideas of how to move forward on it are to either switch ECU's and go to a Microsquirt and see if new tech can dial the fueling in and make it run better, other idea is to swap engines and put either a 2.2 Ecotec or a 3.X J series Honda engine in it and have good reliable power. The reasoning for going Ecotec is I can most likely acquire a whole car with harness/ecm and engine for free, and I have a line on a J35 for $300. Just curious if anyone else has had a similar situation and swapped engines. Thanks in advance!
