Starter question
Badbar88
Anyone know if a the IMI 101-NL (Honda) will work with an LS?
Guess it depends on transaxle and location on transaxle.
See below.
Primary applications
Off-road racing and performance vehicles: The IMI 101-NL is a high-performance part intended for the rugged demands of racing and off-roading.
Volkswagen Type I transaxles: It is designed to fit Volkswagen Type I transmissions, which were originally used in vehicles like the Beetle, Karmann Ghia, and early Buses.
Honda or Acura V6 engine conversions: A key feature of the IMI 101-NL is its extended "snout" or longer pinion, which was specifically engineered to provide clearance for the water neck on Honda or Acura V6 engines when mated to a VW transaxle via a conversion adapter plate.
Transaxles requiring clearance: This starter is also compatible with high-performance transaxles like the Mendeola, PBS, and Fortin. It is particularly useful for Mendeola transaxles with a center-mount starter bell housing, where the extended design is necessary for clearance.
