Summer Upgrade to the SU
Amazing how much more beefy the front of the car looks! cant wait to weigh both of our cars again next season after all these upgrades!
Slow but steady progress. Motor is 90% finished and finally got the rear arms all mounted with new bushings, heims and bolts. Next is the cumbersome job of aligning them.
Car is finally home and now the real fun begins. Remove rear arms to powder them black, pull motor and swap everything over to the BCM closed deck short block, prep CV’s powder the dash and hood and then finally wire it all.
Did you upgrade the front to 2" hollow spindles and hubs or did you keep the combo set up?
Ripped all the old wiring out. 20 years of wiring over 4 owners, it was a mess. So glad to be starting from scratch. Adding an SPod, MSD solid state relay.
Burning the midnight oil to get the wiring done. Gauge cluster harness is completed and loom from gauges to circuit panel is complete. Almost finished with the control center as I call it. I suck at wiring. Please don’t roast it too bad.
Smart move on the Solid State relay. I did the same one.
Got rid of a ton of relays.
put them on the car i cant wait to see this thing buttoned up.
